Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-02-2006, 09:01 PM
dfreise dfreise is offline
Garage is empty, add now
dfreise is starting off with a positive reputation.
Positive for ground?
I've had a restored 64 falcon ranchero for a couple of years. It is a straight six with a generator, not altenator. The odd thing is the positive battery terminal is grounded to the block and the negative terminal hooks to the starting solenoid. The Shop Manual indicates the original set up was negative ground and positive to the starter circuit.
Why would someone switch the factory set up?
  #2 (permalink)
Old 11-03-2006, 06:03 AM
jschira jschira is offline
jschira is gaining momentum as a positive member of FTE.
Quote:
Maybe dyslexia?
__________________
63 Falcon Deluxe Club Wagon
10 F250 Lariat 6.4L
  #3 (permalink)
Old 11-03-2006, 03:27 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
I assume:
The Battery was dead
or
The Battery was blown apart
or
The fusible links were fried !
  #4 (permalink)
Old 11-03-2006, 06:30 PM
tjc transport's Avatar
tjc transport tjc transport is online now
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
some people are just stupid, plain and simple.
with a generator, it is easy to do the pos ground thing.
to switch it back to negative ground, you will need to switch the cables. if you can not re-energize the current voltage regulator, you may have to get a new one.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of almost too many fords.
  #5 (permalink)
Old 11-03-2006, 09:58 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Some of the old time 6 volt systems were positive ground back in the 50's and earlier. They found out later they got much better ignition performance using a negative ground tho so that is the way everything has been wired since. If some addle brained geezer even older than me wired it back up after a major mess he may have wired it the "old" way.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #6 (permalink)
Old 11-04-2006, 02:54 AM
kbolk kbolk is offline
kbolk is starting off with a positive reputation.
hello there, just a couple of questions. Does the truck run with it hooked up that way? Does it charge the battery? R u positive {no pun intended} you looked at it correctly? What i mean by that is that maybe whom ever had it b 4 u might have put new battery cables on it and just hooked up them in reverse[color code] black to pos- red to neg? just a thought!
  #7 (permalink)
Old 11-04-2006, 05:55 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
All Fords were positive ground till 1956.
  #8 (permalink)
Old 11-04-2006, 09:41 AM
kbolk, I does run, just hard to start which often kills the battery. It is hooked backward, I just went out and checked again. Guess there is no telling why the previous owner did it in reverse. Doesn't look like there will be any harm in switching it back, and from one of the post it may even improve the startability. Thanks for the replies.
  #9 (permalink)
Old 11-04-2006, 06:00 PM
Torque1st's Avatar
Posting Legend
Thanks, I did not know precisely when Ford made the change.
__________________
Tags
100, 1961, 50, 64, battery, block, falcon, ford, ground, grounded, negative, positive, ranchero, terminal, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
