Remote starter recommendations? - Ford Truck Enthusiasts Forums
Old 11-02-2006, 12:28 PM
Cam_Man595 Cam_Man595 is offline
Cam_Man595 is starting off with a positive reputation.
I would like to add remote start to my 6.0 Diesel F250 and I need some recommendations from you all. I want remote start capabilities mainly but if there is a security add-on that is not too much more I would be interested in that also. If there are extra bells and whistles that I should know about please let me know. Thanks.
Old 11-02-2006, 05:32 PM
mjlevi mjlevi is offline
mjlevi is starting off with a positive reputation.
I have an Ultrastart remote starter system...it even has a turbo cool-down feature on it...with an l.e.d lighted antenna as a visual only security feature when you lock your doors by the remote...and can be used up to 1750 feet away capability......
Old 11-02-2006, 05:49 PM
Netfly's Avatar
Netfly Netfly is offline
Netfly is gaining momentum as a positive member of FTE.Netfly is gaining momentum as a positive member of FTE.
I went with the DEI Viper 791XV ...Lots of bells and whistles.
directed.com/security/viper/viper_responder.asp
Old 11-02-2006, 08:03 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
IMO combine it with a great alarm system....
Old 11-02-2006, 08:04 PM
Brutus232 Brutus232 is offline
Brutus232 is starting off with a positive reputation.
Just curious, do these remote starters have some sort of delay for the glow plugs?
Old 11-02-2006, 10:24 PM
tvsjr tvsjr is offline
tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.
DEI Viper 791XV here. Great remote start with alarm, two-way remote, all the goodies. If you're into installing it yourself, I bought mine from HookedOnTronics.com for $160 or so.
Brutus - some do. A diesel-approved remote start will have a wire that you hook to the wait-to-start indicator. When the light drops, the unit will fire the starter.
Old 11-02-2006, 10:25 PM
ChaunW ChaunW is offline
ChaunW is starting off with a positive reputation.
I went with the Viper 791XV. Works great... lots of options including cool down and glow plug timer for diesels just to name a few options. I highly recommend it.
Old 11-03-2006, 01:12 AM
wb6anp wb6anp is offline
wb6anp has a very good reputation on FTE.wb6anp has a very good reputation on FTE.wb6anp has a very good reputation on FTE.
The 6.0's don't have a waith to sttart wire to the light it is all computer logic. on a pc board. Atleast I haven't been able to find the wire and the manual say it is logic.
Old 11-03-2006, 01:25 AM
gross30's Avatar
gross30 gross30 is offline
gross30 is starting off with a positive reputation.
I put in an Astro 2WA remote start w/wait to start for 6.0 psd, full alarm system with it etc. Lots of bells and whistles also. There are quite a few models that wont work with the 6.0 psd because there is no wire. I found out the hard way when they tried to install my old remote starter/alarm set up from the f-150. No go. I paid $400.00 cad for the full install w/alarm etc. It seems to work great, so far-so good, and you have to like the exhaust and fan turning on the remote screen when the truck is running !!!! ha-ha. Call me crazy but I like those little perks....dg
Old 11-03-2006, 01:28 AM
ANP - Correct. With the later 6.0s and the Vipers, you use a 528T timer. Simply set the timer to a value long enough to let the glow plugs drop (set based on ambient temperature).
Old 11-03-2006, 06:23 PM
mhoefer's Avatar
mhoefer mhoefer is offline
mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.
Astrostart is the way to go. IMO It doesnt need the trip wire, you set a delay with ignitition. they have various models with alarm, extra button for electric tailgate release if you have a cover, two way page and more.....
Old 11-03-2006, 07:36 PM
EnviroCon EnviroCon is offline
EnviroCon has a good reputation on FTE.EnviroCon has a good reputation on FTE.EnviroCon has a good reputation on FTE.
Quote:
Originally Posted by mhoefer
Astrostart is the way to go. . .
AstroStart (Astroflex) is now owned by Directed Electronics. So, Viper, Clifford, AstroStart, they're all good systems.
I use a Viper 791xv and it's been a good, reliable system for a couple of years now.
Old 11-03-2006, 08:34 PM
jello's Avatar
jello jello is offline
jello is starting off with a positive reputation.
Astrostart..........
Don't forget to hook up the high idle and heated seats to it.
Old 11-04-2006, 01:20 AM
Fomoko1's Avatar
Fomoko1 Fomoko1 is offline
Fomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputation
Does Ford offer factory starters and are they any good?
Old 11-04-2006, 08:38 AM
Quote:
Yes, Ford does offer RS & security systems. They're rebranded Code-Alarm/Audiovox systems. They're pretty good, basic systems, but they're not plug-n-play. They still have to be hardwired into your truck. And none of them offer the 2-way paging that others do and they don't have a lot of the "bells & whistles" add-ons. Window roll-up, additional starter kills, GPS tracking, etc. But they do work with the Ford remote keyless entry, so it works well with the factory door keypad. All in all though, they're not bad.
Remote Start in 2010 E250 jimbomitch 1968-2013 Full Size Vans 27 09-14-2016 10:01 PM
Remote Starter for 2010 kybaseball 2009 - 2014 F150 3 08-10-2015 09:19 AM
Remote start suggestions. Keeseter CO Excursion - King of SUVs 4 12-27-2014 12:58 PM
Looking for recommendations on remote starters rb8484 1999 to 2016 Super Duty 4 11-24-2013 03:48 PM
Remote Start - Plug and Play?? saride 2004 - 2008 F150 10 07-20-2009 05:42 AM
Tags
2005, 2wa, astro, astrostart, diesel, f250, f350, ford, kits, remote, start, starter, starters, truck, viper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
