Source for 10.25 1410 pinion yoke? - Ford Truck Enthusiasts Forums
Old 11-02-2006, 07:17 AM
bigbluetruck bigbluetruck is offline
bigbluetruck is starting off with a positive reputation.
Anyone know where I can get a 1410 pinion yoke for my 1990 axle?
All of them I can find is for the 93+ axles with the longer pinion splines.
I have found a 1410 yoke for a Borg Warner 1345, I can get you the part number on that if anyone wants.
Old 11-06-2006, 04:47 PM
86rustbucket's Avatar
86rustbucket 86rustbucket is offline
86rustbucket is starting off with a positive reputation.
I might be wrong cuz ive never tried it so don't beat me down, but from what i've read, if you cant find the 1410 yoke for pre93 sterlings, why not switch to the later model longer pinion gear? Of course, this would require a new gearset and install, but if you are deadset on the 1410 yoke and you can only find them for +93 axles, it might be your only option. Also, I would assume that the longer pinion would give you more spline length = more strength. And if you are going for 1410 u-joints, why not upgrade the pinion also?
Four wheeler did an article a few months ago on beefing up the sterling and the later model long pinion was one of their recommendations, I don't know how much that's worth to you, but it seems like a good idea.
Old 11-06-2006, 04:54 PM
hoxiii's Avatar
hoxiii hoxiii is offline
hoxiii is gaining momentum as a positive member of FTE.
What's the difference in spline length? If it's not that much, what about putting a spacer behind the pinion nut to get the yoke where it needs to be.
Justin
Old 11-07-2006, 10:23 PM
bremen242's Avatar
bremen242 bremen242 is offline
bremen242 is gaining momentum as a positive member of FTE.bremen242 is gaining momentum as a positive member of FTE.
talk to jess at high angle driveline. he would know for sure.
if you are planning to regear, swap to the newer, longer pinion&ring. They are a direct fit IIRC.
Old 11-09-2006, 07:07 PM
I already tried high angle driveline, they couldn't do me any good. I've got a 93+ style on order. I'll know for sure when I compare it to my old one but I think I can either turn some down off the pinion end of it, or bore it out deeper on the pinion nut end.
Old 11-19-2006, 03:17 PM
KubotaOrange76's Avatar
KubotaOrange76 KubotaOrange76 is online now
KubotaOrange76 has a very good reputation on FTE.KubotaOrange76 has a very good reputation on FTE.KubotaOrange76 has a very good reputation on FTE.
i say good excuse to go to lower gears
Old 10-29-2012, 01:44 PM
86 powerstroke 86 powerstroke is offline
86 powerstroke is starting off with a positive reputation.
installing a dana 80 in 86 sure could use the part # for the 1410 yoke to go onto my 1345 transfer case (fixed yoke) thanks Erik
Old 10-29-2012, 02:43 PM
Sorry dude, after six years a man tends to forget and lose alot of things. If I remember right, the 1410 yoke had a factory application. F-Superduty, maybe? (predesessor to current F-450/550 class trucks, not to be confused with the later current superduty trucks) It might be worth swapping to a 1356 just because this kind of stuff is easier to find for them.
99-06 Factory Disc Brake 14 Bolt Swap tabascom16 1973 - 1979 F-100 & Larger F-Series Trucks 0 03-29-2014 12:38 PM
Divorced NP205 1410 yokes TheTowingCowboy 1973 - 1979 F-100 & Larger F-Series Trucks 10 06-10-2012 05:11 PM
Sterling 10.25 yoke upgrade? 79Ford4x4 Offroad & 4x4 8 07-17-2010 10:06 AM
67 Ford F250 Tranny Question 460-67-FORD 1967 - 1972 F-100 & Larger F-Series Trucks 7 06-22-2010 12:46 AM
np205/np200 yoke to yoke? quadzjr Offroad & 4x4 29 12-02-2007 09:24 PM
Tags
1025, 1410, 2000, 2002, 2006, 90, axel, axle, f250, f350, ford, pinion, short, size, sterling, ujonts, yoke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
