Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 3.0L V6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-01-2006, 05:48 PM
Project79F150 Project79F150 is offline
Garage is empty, add now
Project79F150 is starting off with a positive reputation.
3.0 vulcan, strange Idle.
Hello, Maybe you guys could give me some help on a problem that I have been having. It is not it a ranger but I have the 3.0 vulcan in a 1992 taurus. It has 125,000 miles on it. I am having a problem with it idleing high. When the engine is warmed up and I go from Drive to park the rpms will go up to 2000- 2100 rpms. It will slowly come back down to about 1200 rpm. In gear it will idle at 1000. I have done a complete tune up, replaced the TPS, IAC and the air temp sensor. I have replace several vaccume lines, taken the whole upper intake off and cleaned it and replaced all gaskets. I have gone over every vaccume line with carb cleaner and no change in idle. I have even tried to replace the PCM and still no change.
When the car is warmed up and you unplug the IAC it goes down to normal. Something is telling the IAC to open to much. I am open for sugestions, I don't want to have to take it to the shop. Thanks guys.
  #2 (permalink)
Old 11-02-2006, 11:56 AM
Anyone have any sugestions? I am at a loss here.
  #3 (permalink)
Old 11-02-2006, 09:21 PM
RangerPilot's Avatar
RangerPilot RangerPilot is offline
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
Remove the IAC and clean it out good with throttle body cleaner, see if it makes any difference.
  #4 (permalink)
Old 11-06-2006, 08:09 PM
I replaced it, and it does the same as the old one did.
Tags
30, adjust, complete, ford, high, idle, miles, normal, speed, stutter, tune, vulcan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
