Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Colorado Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Colorado Chapter Join Chapter, Leader: RIKIL
  #1 (permalink)
Old 10-31-2006, 08:05 PM
48 Steel's Avatar
48 Steel 48 Steel is offline
1946 Ford T
48 Steel is gaining momentum as a positive member of FTE.48 Steel is gaining momentum as a positive member of FTE.
Question Best Front clip for 48 F-1
I just picked up a new project and am trying to decide on what I should put under the front end of the 48 F-1 Street Rod truck?
  #2 (permalink)
Old 11-01-2006, 08:55 PM
jrzoffroad jrzoffroad is offline
Garage is empty, add now
jrzoffroad is starting off with a positive reputation.
I have always thought the old Mustang II stuff worked pretty well. You can buy kits that weld up to your exisitng frame using Mustang II front end parts. Some Mustang II's came with 302's and 5 lug front wheels. Although I believe that you can get rotors drilled with any pattern you like. You may have already though about this, but I think the airbags are the way to go for the suspension. I have always stayed away form the volaire and camaro stuff as it isn't ford stuff and I am not a big fan of chopping a frame into two pieces and then welding it back together. Should be a fun project.
__________________
Jerry
67 F100 2wd, SWB 460
67 F250 Crew Cab 4x4
72 F100 4x4 SWB
72 F350 2wd Crew Cab
Tags
48, 52ford, clip, end, f1, f100, front, pickup, put
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
