body lift
Get the 2" bodylift. Very simple to install. No big changes.
I put the two inch body lift on my son's 96. It is GREAT! I am going to get one for my 97 soon. Look for the ebay seller named sportztrailers. They have the kit you need for $107, shipped. It is kit #822. In the tech notes it says it is not for trucks equipped with diesel engine but it fits fine. I called the manufacturer before I bought mine and they said some of the diesels have intercoolers and that can affect the installation. I love what it does for you. It lifts you a little, makes room for your bigger tires, improves the look and it gets you to renew and tighten all of your cab and bed mounting hardware which really made a big difference for us with ride and quietness and squeaks. To see what I mean just stand next to your bed and push on it and see if it moves, or look in the rearview mirror while driving down a bumpy road and swerve gently from side to side and see if your bed slides side to side. Be aware that 3" of lift will require significant alterations to linkage or shifters. Also on the front bumper it tells you to notch your frame for the brackets to fit. I notched my bumper instead and it worked fine.
Ive always said that body lifts are great, when they arent used as the primary lift. We're diesel, but I had a gasser with 6" suspension and 3" body lifts and lost a line off the top of my intank fuel pump. Just to get at the pump one would have to pull the box or drop the tank, if they had no body lift. But I was able to get in there and fix it without having to take a ratchet or any wrenches with me. Another benefit of a body lift, is if you do alot of mudding you can clean your chassis better to avoid premature rotting.
Plus you can get a bigger DP in there. I would think any body lift for a s/c longbox Ford would work. I cant think of any deisel specific body mounts....
Body lifts are pretty cheesy - It's a cheap way to fit larger tires. But yeah - to doing it right can be a lot of work and if you don't do them right they look terrible. Even a good one can still be spotted from a mile away. You might consider a fender trim (And bend up a new fender lip! Just hacking the fenders off looks pretty rough.) Trimming can look pretty slick and is more effective and cheaper than a body lift for less work and headache.
