engine casting number ID ?? - Page 2 - Ford Truck Enthusiasts Forums
Old 10-21-2002, 07:58 PM
286merc 286merc is offline
286merc is starting off with a positive reputation.
Ive found the following has helped me thru the SBF maze.
http://www.cehighperformance.com/ford_block_car_codes.htm
Old 10-21-2002, 09:18 PM
angus angus is offline
angus is starting off with a positive reputation.
Old 06-29-2014, 01:28 AM
GreatSouthernSparky GreatSouthernSparky is offline
GreatSouthernSparky is starting off with a positive reputation.
I also have an engine number that i am trying to identify - The engine number is as follows 6APJ24764F stamped on the side of the block - It is from a 1970 F600 Dump truck - I think it is a 240 I6 - can anyone help me out??
Where is my 302 casting numbers Daltonsheets1995 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 06-01-2012 01:17 PM
Motorcraft Carb Number Jeff L. Davidson 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 05-18-2012 03:40 PM
Ford engine identification number location 77f250kid 1973 - 1979 F-100 & Larger F-Series Trucks 13 02-27-2012 02:24 PM
Engine Serial Number redman84 1994.5 - 1997 7.3L Power Stroke Diesel 7 04-16-2010 02:47 PM
'62 F500 Vin decode & Engine Id Help Needed acm1973 1961 - 1966 F-100 & Larger F-Series Trucks 3 11-08-2005 04:32 PM
Tags
0080e6015a, 302, 351w, cast, casting, engine, find, ford, id, motor, number, numbers, part, search, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
