--Electric Supercharger??--
#31
[QUOTE=Sycostang67]Electric supercharger! If you want more power, just strap on a leaf blower.
http://videos.streetfire.net/search/leaf+blower/0/wm/ab544e3b-5dff-416d-9cfd-a1ad23ca9564.htm[/QUOTE]
that is redicoulous. 50hp gain with a leafblow, blowing
naaaaaaaaaawwwwwwwwwwzzzzzzzzzzz!!!!!1
#32
I wouldn't call them a Super Charger or the electronic turbo charger. They are more of a just a forced Air kit. There are a few problems I have with those. They are always pushing air at the same pressure. The Hi or None! Which come at a cost too used those. It will all ways run lean which can burnt out valve's. The Carb will have problems with tuning it. And Fuel injection will the computer will work the problem out and you will not gain any extra hp. If your going to waste the money with one of these electronic things. Get a good air filter and a modular controlled electronic turbo charger. Or get a fan from a PC and just connect it into your air cleaner.. lol..
#33
hahahaha ohhhh *****!!
All one needs to do now is time the throttle cable for your engine AND a 2smoke leaf blower........
That should be easy....
I am not convinced that an electric `charger` won`t work, but gains will be nominal.
If the average V8 can swallow 850cfm then your electric charger needs to surpass that to make BOOST......
and THEN it needs to be variable to match the engines needs
This is all sounding like it should cost near $5000 or more... isn`t a roush around that price...
#35
#37
Excel Dryer | Hand Dryers | Home
Josh Lee Ponish
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
12-28-2015 10:19 PM
obsidianspider
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
05-19-2013 05:23 PM
