Truck Died At Light - Started Again
So I was sitting at a light yesterday. Ironcially thinking about how well the truck had run. It hadn't given me any trouble since I bought it - specifically the motor. After a minute at the light or so the truck died. Like someone turned the key off. It restarted like normal and I drove away.
I've been out wheeling in the mountains with the truck running for 6 hours or more at more or less and idle with no trouble. Do we think this might be the CPS? Do they fail that way? I've been meaning to buy a spare but haven't yet. There was no check engine light. Infact I don't think I've ever seen a check engine light - even koeo. Is my light burned out or something?
Okay this sucks... Had it stutter on the highway and die at stopsign. Highway was like a week ago and stopsign was this morning.
Wheres the best price on these things and how much?
$180 from Autozone it Looks like.
Ebay isn't happening - everything is for the newer trucks.
I take it these things can last years. I've seen a truck go no less than 5 years with no trouble.
Originally Posted by DAN-D-DIESEL97
more than like cps.mine did same thing,then it started to get more frequent.
I would start @ the CPS and see if it is the cure.
Obs Cps
I BOUGHT MINE ON E-BAY, AND I HAVE A 97 PSD CREWCAB. DON'T ASK ME WHO I BOUGHT IT FROM, I DON'T REMEMBER. JCAB
Yes.
- Check voltage between the CPS terminals PWR GND and CID.
- With the engine running, voltage should be greater than 0.1 volt AC and vary with engine speed.
- If voltage is not within specification, check for proper voltage at the VPWR terminal.
- If VPWR voltage is greater than 10.5 volts, sensor may be faulty.
