Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 10-30-2006, 01:12 PM
mongo75's Avatar
mongo75 mongo75 is offline
Garage is empty, add now
mongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to all
danny jones
Need help getting started
I've read alot of posts, I've done a lot of searching, and I really want to start making my own Bio. My problem is that I can't afford a $3000 set up, and I am kinda limited on available space. I was looking for sugestions / instructions on how I can start a simple small operation in my garage / side of house. Do I need to wash it, and if not will not doing so save space? Thanks all for any advice!!
__________________
Danny PAA member #12
SoCal Chapter Member
E99 F-350 Dually Van turbo 4x4 CC LB 7.3L, AFE intake, 3 gauge pillar, 4" Magnaflow SS str8-pipe, DP Tuner, Swamps 175/146 SS inj, ARP head and bottom studs, Comp 910 springs, ITP Ovrbst, CCV mod, SS HPX, home made Reg-return, Foil Del, ZooDad, Air Horns 320hp/704tq
  #2 (permalink)
Old 10-30-2006, 06:41 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Quote:
Your in luck! GirlMark has a biodiesel build class this comming weekend Nov 4-5 in Berkely Ca. You can register for her class here: http://www.girlmark.com/tour
She will be showing how to build an "appleseed" style processer, and usually uses kits from here: http://www.b100supply.com/index.cfm?...TOKEN=83982429
If you can't make it to her class, you can get all the info on building your own processer here: http://www.biodieselcommunity.org
Most people will tell you that you need to wash your bio, I however do not beleve in adding water to my biodiesel! I use Magnesol to clean my biodiesel. You can find more info on Magnesol here: http://www.fryerpower.com/store/page1.html
Good luck, and let us know if we can be of any help! FABMANDELUX.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 10-30-2006, 06:50 PM
mongo75's Avatar
danny jones
Thanks Fabman- I won't be able to make the 600 mile trip though! I'll check out the other sites you mentioned, and maybe she'll have another class nearer to Orange/ LA county someday. Besides, I wouldn't want to go to Berkely and be misconstrued as a tree huggin' hippie LOL....
__________________
  #4 (permalink)
Old 10-30-2006, 07:07 PM
1935 Ford pickup
Check out my gallery, The processer I built cost me less than $200, and I've made more than 8,000 gallons! I use a completely different processer that I designed myself, and I do not water wash my bio..............And I hear ya about the Berkely thing.......They would have to drag me kicking and screaming to get me anywhere near that place!
FABMANDELUX.
__________________
  #5 (permalink)
Old 10-31-2006, 11:57 AM
mongo75's Avatar
danny jones
Fabman- do you have a "general" recipe you follow? I understand that you have to do a titration test first, but what about the amount / ratio of magnasol that you use? Any ideas on what the best chemicals are to do a test with are? And what do you think of the water heater "appleseed" processor for a newbie to making biodiesel- do you think this is a better way to start? Thanks!
__________________
  #6 (permalink)
Old 10-31-2006, 08:11 PM
1935 Ford pickup
I have an exact formula that I have developed for the oils that I pick up. I haven't titrated my oil in over 2 years. I've found that the titration results were always so close that I was not saving much money and wasting a lot of time for nothing. I made 1ltr test batches in varing amounts till I found a formula that worked for me. As an example: If you titrated your oil and figured out the exact amount of Lye required and mixed just that amount, then any water showed up in the mixture, the water will form a side reaction and "pull" some of the Lye out of the Methoxide forming soap. This will not allow a complete reaction, and has the potential to form "glop", thus waisting a batch of bio. By using slightly more Lye than required you will force the reaction to completion, thus saving the batch. since I've quit titrating I've not had a bad batch yet! My formula is 25 gallons oil + 5 gallons Methanol + 3pounds KOH
The amount of Magnesol required depends on if you remove the Methanol from the biodiesel first. I remove the Methanol first, so I can get by with less Magnesol I use 1 percent Magnesol by weight= 1 pound of Magnesol to 100 lbs of biodiesel. If you don't remove the Methanol first it requires 2 percent Magnesol by weight.
As to the appleseed processer this should express my thoughts on the matter: http://www.ford-trucks.com/forums/51...ed-newbie.html
Post #2
For testing your Biodiesel go to http://www.biodieselcommunity.org They have all the info you need for testing your bio.
FABMANDELUX.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
