2000 V8 5.4 Ford F-150 Firing order.
reason I asked for the firing order is because I got a P0306 Code and description for that is "Cylinder 6 Misfire Detected." Isn't spark plugs firing order corresponds to each cylinder? If not, I need the location of the cylinder. Also, If you have an idea of which I need to look on first, for the issue I'm having, I'll really appreciate that. The vehicle all of sudden started shaking and lost power. I was even pulling a boat when it happened. It runs so bad in low rpm and will smooth a little bit out and be driveable with high rpm (atleast 2500 rpm). Went to AutoZone today and they lend me their scanner and I got P0306 "Cylinder 6 Misfire Detected." I haven't start doing anything yet, but leaning towards the spark plug, then the coil. But I can't even find the spark plug and don't have a trace as this engine (V8 5.4) don't seem to have a regular spark plug wires. If someone can also help me locate where the plugs are, it will be highly appreciated. Thanks.
valiantski take a look at https://www.ford-trucks.com/forums/1...ur+spark+plugs
Welcome to the forum Allen
I would bet anything that it is your coil....I had the same thing happen a few yrs ago and that is exactly what it was...it was the #8 coil...a real p-i-n-t-a spot to boot...you just have to take off the fuel rail and can access them...not so bad really ...took me 30 minutes and had never done it before...
I am having the same problem on my truck. 2000 f150 v8 5.4. Code read that cylinder 2 is misfiring and I can definately feel it. I think I might have had some bad gas in it plus the tank was just about empty when this started. I'm not sure if that has anything to do with it or if it was just a coincidence in timing? Any tips or pointers you can give me before I dig in? Are the plugs worth the difficulty of getting them out, or should I just take it in? Thanks... Tom.
