2000 V8 5.4 Ford F-150 Firing order. - Ford Truck Enthusiasts Forums
Old 10-30-2006, 02:03 PM
valiantski valiantski is offline
valiantski is starting off with a positive reputation.
Hello All,
Can someone please post the firing order of 2000 F-150 V8 (5.4L) engine. Thanks.
Old 10-30-2006, 02:50 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Welcome to the forum
Do you want the actual firing order or where the cylinders are located?
4 8
3 7
2 6
1 5
front
Old 10-30-2006, 08:09 PM
reason I asked for the firing order is because I got a P0306 Code and description for that is "Cylinder 6 Misfire Detected." Isn't spark plugs firing order corresponds to each cylinder? If not, I need the location of the cylinder. Also, If you have an idea of which I need to look on first, for the issue I'm having, I'll really appreciate that. The vehicle all of sudden started shaking and lost power. I was even pulling a boat when it happened. It runs so bad in low rpm and will smooth a little bit out and be driveable with high rpm (atleast 2500 rpm). Went to AutoZone today and they lend me their scanner and I got P0306 "Cylinder 6 Misfire Detected." I haven't start doing anything yet, but leaning towards the spark plug, then the coil. But I can't even find the spark plug and don't have a trace as this engine (V8 5.4) don't seem to have a regular spark plug wires. If someone can also help me locate where the plugs are, it will be highly appreciated. Thanks.
Old 10-30-2006, 09:11 PM
astroo astroo is offline
astroo is starting off with a positive reputation.
The plugs are under the cop's, which are coil packs that are on top of each plug. Also, there are no plug wires, just the wires whic attach to the cop's. The plugs are just outside each fuel rail on each side. It can be rather tricky to get to the plugs. Good luck.
Allen
Old 10-31-2006, 12:33 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
valiantski take a look at http://www.ford-trucks.com/forums/10...ur+spark+plugs
Welcome to the forum Allen
Old 10-31-2006, 08:53 AM
02 LariatFX4 02 LariatFX4 is offline
02 LariatFX4 is starting off with a positive reputation.
I would bet anything that it is your coil....I had the same thing happen a few yrs ago and that is exactly what it was...it was the #8 coil...a real p-i-n-t-a spot to boot...you just have to take off the fuel rail and can access them...not so bad really ...took me 30 minutes and had never done it before...
Old 10-31-2006, 09:05 AM
Thanks Guys, I will update you guys soon as I get a chance to work on it, most probably this coming weekend. Again, thanks a bunch.
Old 10-31-2006, 09:09 AM
One more quick question, based on the spark plugs/Coils firing order, is the #6 would mean Cylinder 6? Because code I'm getting at calls for "Cylinder 6 Misfire Detected" and I wanna make sure that I will be working on the right plug and coil. Thanks and hope to hear from you guys soon.
Old 10-31-2006, 09:21 AM
Racerguy's Avatar
A P0306 is for #6 cylinder.....the second one back on the driver's side.
Old 10-31-2006, 10:04 AM
Hi RacerGuy,
From this firing order:
4 8
3 7
2 6*
1 5
Front of the vehicle.
Please verify if this correct. Thanks.
Old 10-31-2006, 10:39 AM
Racerguy's Avatar
Yes that's right.
Old 10-31-2006, 07:09 PM
Warren F-150 Warren F-150 is offline
Warren F-150 is starting off with a positive reputation.
You do not have to take the fuel rail off to change plugs or COP.
Old 10-31-2006, 07:16 PM
Munky's Avatar
Munky Munky is offline
Munky is starting off with a positive reputation.
Yeah I'd bet it's the coil. Mine did the same thing except the 2 cylinder and I replaced the coil and no problems since. Just remember when you replace it, you can disconnect the negative cable on your battery for 10 minutes to reset the SES light.
Old 11-02-2006, 08:27 PM
Thanks Guys! I just fixed the problem and yes, it was the "COP" # 6. Cleared the code and when i started the engine can tell right away that problem was gone. Drove it few miles in the freeway and i'm glad that it is back to normal now. Again, thanks for all your input.
Old 06-14-2009, 05:26 PM
tezra12 tezra12 is offline
tezra12 is starting off with a positive reputation.
I am having the same problem on my truck. 2000 f150 v8 5.4. Code read that cylinder 2 is misfiring and I can definately feel it. I think I might have had some bad gas in it plus the tank was just about empty when this started. I'm not sure if that has anything to do with it or if it was just a coincidence in timing? Any tips or pointers you can give me before I dig in? Are the plugs worth the difficulty of getting them out, or should I just take it in? Thanks... Tom.
2000 E250 5.4 L V8 Intake Manifold smoovmusic 1968-2013 Full Size Vans 1 03-24-2016 11:26 AM
Speedo Calibration bass-n-fire 1997 - 2003 F150 1 03-08-2016 07:04 PM
firing order on 2003 f-150 Triton 5.4L jeange 1997 - 2003 F150 5 07-06-2006 06:28 PM
firing order for 5.4 rowdie-stang 1997 - 2003 F150 3 08-09-2005 08:59 PM
Any 2000 F-150 5.4 upgrades kammerud Computer Chips & Tuners 2 08-22-2002 06:04 PM
Tags
150, 1997, 2000, 2001, 2002, 54, cylinder, f150, fire, fireing, firing, ford, order, po306, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
