48 6 cyl
48 6 cyl
Your vin should read *87HY 110140* and lower OR *87HD 110141* and higher. Ford changed the designation mid-year. In either case your original engine would have been a 226 cu in flathead.
Ford didn't use serial numbers on their blocks, so if you have any 226 flathead you have a numbers matching engine. If your vin is different that the above examples, let me know.
>I have recently bought a 48 F-2. As far as I can tell when
>I ran the codes on the truck it came factory with a 6 cyl.
>My question is how do I find out if it is the original
>engine or at least the same kind, that came in it? Thank
>you for any advice!
>you for any advice!
