Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 van SPONSORED BY:
  #1 (permalink)
Old 10-30-2006, 10:03 AM
Odge Odge is offline
Garage is empty, add now
Odge is starting off with a positive reputation.
Talking Maximum safe boost for 6.0
I removed the muffler from my truck and the cat fell off and now I am hitting about 25 pounds of boost without much effort . So the questions is, what is a safe amount of boost for the 6.0?
I know there are alot of people who have modded their trucks and are getting some serious boost but what is safe. Is there a maximum setpoint set at the factory?
I have an Edge A2 that I mostly run on stock or 1. I bought it mostly to watch what the motor is doing. Most of the time I don't even look at the dash just at the A2 for EGT and engine stats.
  #2 (permalink)
Old 10-30-2006, 10:26 AM
f-350 turbo's Avatar
f-350 turbo f-350 turbo is offline
f-350 turbo is starting off with a positive reputation.
I think the max boost that you can put to the 6.0 and be safe is the amount of boost right before you stretch your head bolts and pop you head gaskets. From what I have read there have been 3 revisions on head gaskets and one on head bolts so I think its going to depend on what revision your truck has.
  #3 (permalink)
Old 10-30-2006, 10:42 AM
I bought my '07 in August, so I would imagine that it has the newest revision. I haven't checked the engine build date but might see if I can find it today, if the weather holds out.
  #4 (permalink)
Old 10-30-2006, 10:45 AM
2006PSDSD 2006PSDSD is offline
2006PSDSD is starting off with a positive reputation.
The max boost you want to run on a 6.0 is 38 psi, without doing anything else to your heads, gaskets, studs. Like f-350 turbo said though, the studs and gaskets have been changed a number of times, so not to say that you can't damage anything but, that's what I have been told by powerstroke builders is the number. I would set your Edge to backdown at like 30-33 psi, just to be safe.
  #5 (permalink)
Old 10-30-2006, 11:05 AM
BowTieHatr BowTieHatr is offline
BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.
25 psi is perfect, not to low, not to high. once you hit 30 psi your bolts start growing little by little day by day.
  #6 (permalink)
Old 10-30-2006, 11:34 AM
badbrad60's Avatar
badbrad60 badbrad60 is offline
badbrad60 is starting off with a positive reputation.
Over the weekend I had my truck in Level 7/7 merged on the freeway until 97mph. The PDA alarmed at 35PSI and the EGT's hit 1460 deg F. I never see the stock gauge hit the numbers that the PDA hits. Seems like it is just slower to respond or does it just interpret info differently. Which gauge is more accurate? Am I really hitting 35psi? poor stretch bolts........
__________________
06 6.0 DRW 4.10s, level, 285/70/17, Airlift bags, Banks PDA&Intercooler, Spartan & IDP xCAL2, Traction Bars, Line-x FASS 150/180, ITP RRFS, 165cc Inj, ARP's, Sneaky pipe... Pullin a 40 foot Warrior
http://209.235.246.58/Secure/images/...1097_small.jpg
  #7 (permalink)
Old 10-30-2006, 12:02 PM
GLAMIS GLAMIS is offline
GLAMIS is starting off with a positive reputation.
Hey badbrad60 what does a 40' full throttle WW trailer wieght? and what level do you tow in? I have a 38" Next level fifth wheel that I havn't towed seen I got my tuner.
  #8 (permalink)
Old 10-30-2006, 12:11 PM
Bowtie, I have my alarm set at 23 and defuel/backdown set at 25. Since the cat fell off every time it downshifts under load I get that alarm going off. I haven't tried pulling with the truck since I pulled.... umm...the cat fell off. I have noticed that my egt's are running a lot lower. Will keep you updated.
Thanks
  #9 (permalink)
Old 10-30-2006, 12:26 PM
badbrad60's Avatar
Glamis, I haven't taken it to the scales yet, but calculated, it is about 16k loaded. I have towed in all the levels, but to avoid grenading the motor I try to keep it at 3/7, sometimes bumping it to 4.
Odge states that he has defueling at 25? If I had mine doing that (thru the PDA) I would be defueling all the time. So, my question still stands...which gauge is more accurate? Stock or PDA?
__________________
  #10 (permalink)
Old 10-30-2006, 12:57 PM
raptor131's Avatar
raptor131 raptor131 is offline
raptor131 has a good reputation on FTE.raptor131 has a good reputation on FTE.raptor131 has a good reputation on FTE.
Thanks
so if i understand you correctly the boost never went this high until the exhaust change? or is it from the tuner? mine never hits anything higher than 25lbs by the stock gauge or my autometer. but then again i have the egr disconnected. i hear that makes a difference of the boost levels is that true? if so what is the status of your egr?
__________________
05' silver f-350 lariat 6.0 psd 4x4 crew cab drw, 4"inch turbo back exhaust, BPD oil cooler condenser mount, powermax turbo,dc power 190Amp OEM High Output Alternator , coolant filter, auto meter: boost, coolant temp, trans temp, egt, voltage. scan gauge II, Rds 91 gallon fuel tank toolbox combo, ready lift 2.5 leveling kit, blue spring mod.Fumuto oil drain, AE w/ford enhanced bundle.Air lift 5000 series rear air bags
  #11 (permalink)
Old 10-30-2006, 01:09 PM
This is Odge's wife and it is MY TRUCK!!! And if I have to take any more cats that fall off that truck to the vet I'm gonna kill him!!!
  #12 (permalink)
Old 10-30-2006, 01:55 PM
bneafus's Avatar
bneafus bneafus is offline
bneafus is starting off with a positive reputation.
F...ing MEOW!!!!
__________________
'05 Harley F350 SD Blue
'99 Softail Custom Chopped
  #13 (permalink)
Old 10-30-2006, 04:38 PM
CanadaGuy CanadaGuy is offline
CanadaGuy is gaining momentum as a positive member of FTE.
30 psi is pushing the limits of the headbolts. I know somebody said 38 psi, but if you ask me, that's suicide!
__________________
Ford Senior/Master/Diesel Technician in the Greater Toronto Area. Contact me for help getting your vehicle serviced. Do not contact me with anything pertaining to performance modifications.
  #14 (permalink)
Old 10-31-2006, 01:44 AM
Thanks guys, I think I will stick with the set points I have. They seem to be safe by everyones standards.
It really is my wifes truck, I just get to maintain it. I stayed completely out of the decision making when she picked it out. She did a heck of a job though, it is a gorgeous truck.
  #15 (permalink)
Old 10-31-2006, 04:31 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has much to be proud ofnpccpartsman has much to be proud ofnpccpartsman has much to be proud ofnpccpartsman has much to be proud ofnpccpartsman has much to be proud ofnpccpartsman has much to be proud ofnpccpartsman has much to be proud ofnpccpartsman has much to be proud ofnpccpartsman has much to be proud of
LMAO--I'm in a very similar situation. I however do get to drive it quite frequently, it's just not my daily driver.
__________________
Payin it Forward one post at a time
I look at it like this: The advice is free and you get what you pay for; use it or dont my truck still runs fine. From a very well respected friend....Thanks
Tags
30, 60, boost, egt, find, ford, gasket, head, max, maximum, model, odge, pound, revision, safe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
