Go Back   Ford Truck Enthusiasts Forums > Diesel > Competition
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Competition Diesel racing, sleds, dynos, power tuning and max performance.
  #1 (permalink)
Old 10-29-2006, 10:59 PM
Lance_I Lance_I is offline
Garage is empty, add now
Lance_I is starting off with a positive reputation.
Stupid Question
I've seen guys at the strip driving sticks doing burnouts ad loading their turbo before they take off. My question is since I've never ran my truck on the strip is how do they do this? Do they have and extra foot or something?
__________________
01 F250 PSD 7.3 SC, Sprlift 4" lift 35" GYR MTR, Airaid intake, Bnks IC, Bhead wg, turbine housing,DP-Tuner Stk,No Strt, 60,80,100,120,140,smk,hi idle, Bnks whl, 5" Mflow, wg disable, Autometer gauges, Zoodad,Sp 18K,Sth Bnd Clutch,CCV,AIH del w/bst,EBPV del, SP ovrbst kill, Crower Rods, Hstuds
  #2 (permalink)
Old 10-29-2006, 11:30 PM
powerstroker27 powerstroker27 is offline
powerstroker27 is starting off with a positive reputation.
i believe you have to put your left foot on the clutch and the right half on the brake and half on the accelerator using the toe end of your foot to push the accelerator down farther. I have a 6speed but have never tried this due to my slipping clutch so hopefully someone who has a little experience with this will chime in and correct me if im wrong.
  #3 (permalink)
Old 10-29-2006, 11:43 PM
SpartanDieselTech's Avatar
SpartanDieselTech SpartanDieselTech is offline
FTE *******
SpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to all
powerstroker27 has this one covered. It's called "heel-toeing", and is the only way to properly launch a load-dependant engine such as a turbodiesel with a manual transmission.
  #4 (permalink)
Old 10-30-2006, 01:22 AM
Thanks I'll have too play around with it tommorrow. I just never really knew. With my upgraded brakes I will kill the engine before I can build any boost. I thought maybe the guys I've sen doing this had double disc clutches. Powerstroker27 get a good aftermarket clutch and you won't have to worry about slipping anymore. I can't make mine slip no matter how hard I try. I got the South Bend Con FE. I think it's advertised at 550hp but it will hold more.
__________________
  #5 (permalink)
Old 10-30-2006, 07:18 AM
IB Tim's Avatar
IB Tim IB Tim is offline
Site Administrator
1989 Swift DB4
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
"heel-toeing"...great for road racing also
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
  #6 (permalink)
Old 10-30-2006, 10:41 AM
Okay so if I understand My entire left foot should be just on the clutch. My heel on my right foot should be one the brake and the toe end of my right foot should be on the throttle. Is that right? Looks like it will take some practice and getting used to.
__________________
  #7 (permalink)
Old 10-30-2006, 11:37 AM
Quote:
This i fully understand but my wallet and bank account have something else to say at the moment. Hopefully by this spring i can have the money put aside to get a clutch and then i will be able to hook my chip back up and actually be able to accelerate at a faster than grandma speed without things slipping.
  #8 (permalink)
Old 10-30-2006, 01:27 PM
bassproguy07 bassproguy07 is offline
bassproguy07 is starting off with a positive reputation.
Ok I'm an expert at heel toeing, and I put my toes on the brake and heel on the gas. Not the other way around
__________________
1983 F-250, 6.9 XLT REAL P.O.S!
  #9 (permalink)
Old 10-30-2006, 01:35 PM
So can you completely let out on the clutch when you do this? I'm just trying to learn how to do a burnout and stay pretty much in one spot. I've got a friend with an auto in dodge and he makes me look bad by doing burnouts all the time. I know I've got the faster truck but I can't do a burnout to save my life.
__________________
  #10 (permalink)
Old 10-30-2006, 02:56 PM
Quote:
Well i guess it could work either way then. Have you tried it both ways to see if there is a better way or more comfortable way of doin it? I would like to know so when i get my clutch i can show my rice burner friends how to do a real burnout .
Lance_I,
do you have any pics of your truck? it looks like from your sig that you have the same thing as me except for you already have most of the mods that i want on mine. Also, how does the con fe clutch handle in normal daily driving and when ever you really get on it?
  #11 (permalink)
Old 10-30-2006, 03:43 PM
I've got pics but can't figure out how to upload them. I'll work it later. My clutch feels completely normal. I did have to removethe tension spring after I installed it because it was way to soft. Now I can't really tell the difference between it and the way my stocker felt. It's great for daily driving but if you wanted one that's a little more drivable get the Con Ofe. I had it before upgrading to the con fe. Really gettin into it it holds like no other so you get planted to the seat pretty good. You would think me being a carhauler and using one foot for the brake and gas all the time when I'm loading I could do it in my truck. I can't get comfortable doing the heel toe no matter which way I try.
__________________
  #12 (permalink)
Old 10-30-2006, 08:28 PM
well if you really want to be able to do that big burnout without tearing up your brakes and rotors then another thing you could do would be to get a line lock kit. That way you wouldn't have to use the brakes and would be able to control everything easier, plus not tear things up as much.
  #13 (permalink)
Old 10-30-2006, 09:28 PM
I just talked to my dad and he has a B&M launch control that he's gonna give me. I gotta feeling I'll need tires by the end of the week.
__________________
  #14 (permalink)
Old 10-31-2006, 04:15 AM
ryaneverk2's Avatar
ryaneverk2 ryaneverk2 is offline
ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.
Heel & toeing is most often used in road racing, like Tim said. Usually used to downshift smoothly from say 5th gear to 2nd gear. You clutch w/ the left foot, while breaking w/ the right toe (otherwise you'll be going way too fast for 2nd gear), while also heeling the accelerator to blip the RPMs way up to where they'll need to be in 2nd gear. Then you go through the turn, and are already in 2nd gear to power out of it hard.
I think if you do a search on google for performance manual driving or heel-toe or something like that, you can probably find little video clips of an instructor driving along demonstrating the technique.
__________________
Ryan Arthur
* Sold * 2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator/tee, ATS housing, BBHA, CCV Mod, SS HPX, DP-Tuner, BTS-VB, lots of LEDs, and more...
My Truck Pics
Tags
clutch, con, fe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
