abs problems can't drive
Im sure there are more knowledgable folks than me, but I dont think the two issues are related. On my 95 the ABS comes on intermittently but it doesnt affect how it shifts. There is, I believe, a switch at the brake pedal that when depressed actuates a release so you can shift into drive. It's there for safety reasons. Perhaps the switch is bad or the release mechanism(lock) is bad at the column.
I had something similar happen to me with my 98 F150. I was putting in a stereo when I grounded a hot wire. Truck started fine, but wouldn't go into gear. Don't remember the abs light. but anyway I had blown a 50 amp fuse under the hood. Replaced it and everything worked fine. Check your fuses. Also the moral of the story is, disconect the battery when doing electrical work.
