Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-29-2006, 09:15 PM
ford1967 is starting off with a positive reputation.
2.3 L ford tempo problem
ok guys. My brother just bought a 1990 ford tempo 2.3L motor auto tranny 133K miles. so heres the problem. at idle in park motor has no miss at all you can rev it up in park and sounds perfect, when go and drive the car at about 2000 to 2500 rpms the car will fall on its face horribly. it does it in all 3 gears. sometimes when just shifting to drive the motor will start shuddering. i checked the tps, iac motor, plugs, wires, cap and rotor, firing order. i did check the tranny fluid and it smelt a little burnt. i was kinda thinkin it was the tranny but not for sure. thanks in advance for the help.
ask me with any questions
__________________
1967 swb flareside
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 10-30-2006, 01:20 AM
TigerDan's Avatar
TigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud of
First thing is to pull the codes. Always start there with an EFI engine. I suppose transaxle problems are a possibilty, maybe the tq. convertor. Burnt fluid isn't a good sign.
The Tempo 2.3 is a different critter from the 2.3 used in Rangers/BIIs that we cover here.
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
  #3 (permalink)
Old 10-30-2006, 10:24 PM
yea i knew that it was a different critter. tigerdan thanks for your help i tinkered with it a while to night and notice that the previous owner had left the distributor loose, very loose. that caused it to run good until the motor had stress on the cam and move the distributor off timed. thanks for your help
__________________
1967 swb flareside
  #4 (permalink)
Old 02-21-2007, 08:50 AM
srod is starting off with a positive reputation.
Have you tried a new fuel filter? My son drives a 94 tempo and unless we change the fuel filter annually he has similar problems..
otherwise the Tempo 2.3 has been a great little car...
  #5 (permalink)
Old 12-19-2007, 01:04 PM
newbyyhead03 is starting off with a positive reputation.
just do NOT let that motor get hot. ford didnt put large enuff waterways in that head so thay are extremly prone to cracking. they are good cars if they dont get hot. i drive a 87 and just had to put a new head on mine after searching for 3 mnths. if it does crack good luck finding another i had to order mine 4 states away and it had internal cracks. week later ai stumbled across one in a field(tempo)
  #6 (permalink)
Old 01-11-2008, 09:57 PM
rikard is starting off with a positive reputation.
Sounds like it might be a clogged exhaust system. When my cat got plugged it acted the same.
regards
rikard
__________________
1994 Red F150 SB 300 5spd 3.55
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
