Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-28-2006, 09:17 PM
chrono4's Avatar
chrono4 chrono4 is offline
chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all
Made a new front bumper
made a new front bumper outa some structural c channel we had around. I got tired of messing up my front bumper, and I needed a place to hook to when pulling people (and being pulled).
what I started with:
good ole tsc d rings, mig turned all the way up to weld um on
The finished product: Im going to make one exactly like it for the rear, only there will be a reciever in the middle and a traingular brace on the backside. Total cost 13$
__________________
--Andrew--
Rocking a 79' f150 with a 300 and a 4 speed........
Full York OBA Install
Welding a 9"
Very simple front bumper
Lowering Spring Towers
Hi, I'm Andrew and I have a wheelin problem that is often disrupted by fabbin and drinkin, glad to meet yall.
STGs MinionsTechnical Advisor
  #2 (permalink)
Old 10-28-2006, 09:45 PM
rebocardo rebocardo is offline
rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold
That looks slick! I have some 8" x 1/4 C channel hanging around I never used because my welder isn't good enough. Your picture motivates me to tack weld it together and bring it somewhere. My current bumper is almost twisted in 1/2.
Those D rings look beefy, what are they, 1"?
  #3 (permalink)
Old 10-28-2006, 09:49 PM
chrono4's Avatar
Not sure on the size of them, they were the biggest Tractor Supply had, and they were rated for quite a bit. Mine was pretty mangled, the bottom was bent in pretty good, and the drivers side was pushed in, almost touching my fender and grill.
__________________
--Andrew--
Welding a 9"
  #4 (permalink)
Old 10-29-2006, 12:36 AM
chrono4's Avatar
starting to look for a winch, anybody have any pic of a hidden winch on a bumper somewhat like mine? I want put mine up behind the bumper, just not sure if it would fit.
__________________
--Andrew--
Welding a 9"
  #5 (permalink)
Old 10-29-2006, 06:18 AM
Thomasm67's Avatar
Thomasm67 Thomasm67 is offline
Thomasm67 is gaining momentum as a positive member of FTE.
Hey Drew try this site they have some of the cheapest prices on winches that i have seen.
http://www.winchdepot.com/index.asp
__________________
Only the Best and Finest Drive Ford Trucks in the
Kansas Chapter
76 F250 Hiboy/390/35's/4.10's
92 Explorer/3.73's/4.0/235's
  #6 (permalink)
Old 10-29-2006, 10:45 AM
chrono4's Avatar
anybody ever heard of rand winches? http://cgi.ebay.com/ebaymotors/Rand-...49989301QQrdZ1
__________________
--Andrew--
Welding a 9"
  #7 (permalink)
Old 10-29-2006, 09:02 PM
Thomasm67's Avatar
Sometimes those type of winches are made by warn or milemarker and Ramsey they just put a different name on it.
__________________
Kansas Chapter
  #8 (permalink)
Old 10-30-2006, 12:07 AM
RotGrubestier44's Avatar
RotGrubestier44 RotGrubestier44 is offline
RotGrubestier44 is gaining momentum as a positive member of FTE.
The 12,000lb MileMarker Hydraulic winch (the one I have my sights set on) is cheaper on Bronco Graveyard. http://broncograveyard.com/bronco/i-..._winch_kit.htm
__________________
Jeep... Its whats for Dinner!!!
The problem is Mud. The solution is Ford.
www.workingpitbull.com
www.broncograveyard.com
www.buckstop.biz
  #9 (permalink)
Old 10-30-2006, 11:46 AM
MBBFord's Avatar
MBBFord MBBFord is offline
MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold
That looks pretty good.
Should hold up alot better than that stock bumper.
About how much did it weight?
__________________
79 Bronco 400 C6 NP205 D44 9" 4.56 gears Lockers 6" lift and 37" SS Iroks
77 F-100 302 C4 D44 31" M/Ts
04 F150 Lariat Screw 4x4 2"AS 32x11R17 Hankook M/Ts or 34x10.50-17 SS LTBs
  #10 (permalink)
Old 10-30-2006, 09:29 PM
Ford150/428/dud's Avatar
Ford150/428/dud Ford150/428/dud is offline
Ford150/428/dud is starting off with a positive reputation.
I thought about making my bumper out of a big steel pipe and using to to hold air. But that bumper looks pretty damm good. I have a change of plans.
  #11 (permalink)
Old 10-31-2006, 11:15 AM
Thomsen Thomsen is offline
Thomsen is starting off with a positive reputation.
Nice work.
__________________
1970 Highboy 4X4: 466, NP-435, Dana 60's, 42'' Iroks
1978 F-150 swb 4X4: 400, NP-435, 205, 35" Mudders
1979 F-150 4X4: 466, C6, 203, 38.5" Boggers
1986 F-350 CC 4X4: 6.9 IDI, T-19, D60/Sterling
1989 F-350 4X4: 7.3 IDI, ZF-5spd, Banks Turbo
1994 F-150 4X4: DD, 5.0, AOD
  #12 (permalink)
Old 10-31-2006, 11:51 AM
Ronin4x4 Ronin4x4 is offline
Ronin4x4 is gaining momentum as a positive member of FTE. Ronin4x4 is gaining momentum as a positive member of FTE.
That turned out real nice looking! Cheaper and stronger then what you can buy to. Nice!
__________________
Ford-man Forever!
  #13 (permalink)
Old 10-31-2006, 09:12 PM
fishmanndotcom's Avatar
fishmanndotcom fishmanndotcom is offline
fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE.
dam man, that chit looks good! way to be productive! the weather around here has been very conducive to getting chit done
-cutts-
__________________
My Google Photo Gallery
-96 F350 4x4 ZF5 CC/LB, 37" SSR's, D66 turbo, Stage-1's, Banks IC, 5" stacks, York OBA
-72 Bronco 302/NP435/D20/D60/10.25 welded F/R, full hydro, hydroboost, 39"iroks
  #14 (permalink)
Old 10-31-2006, 09:59 PM
chrono4's Avatar
Well I dont think I'm going to spring for the winch just yet. A tow company near our storage lot has a f350 wheel lift tow truck, and I think I had the single 8 or 10 k hydro winch on it, and I''m going to see if he'll let it go. the truck burnt up the cab, so I think itll go pretty cheap, Im just hoping its ok.
__________________
--Andrew--
Welding a 9"
  #15 (permalink)
Old 11-01-2006, 12:37 AM
captain p4's Avatar
captain p4 captain p4 is offline
I'll sleep when I'm dead
captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold
looks awesome
__________________
-Paul
-88 Mustang 5.0/5spd mild restoration in progress
-78 Bronco 460 and things
-2003 F350 Supercab shortbed FX4 6.0 PSD
Quote:
Originally Posted by STGFordCrazy04 View Post
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
