Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-28-2006, 02:51 PM
WerbyFord WerbyFord is offline
Garage is empty, add now
WerbyFord is starting off with a positive reputation.
Unhappy Adj Rocker Arm C3TE-6564-A is this 534??
I have 2 rocker shafts, they are 406/427 style but have 5 stands [with 1 at each end] and from first-to-last rocker is over 1" longer than the FE setup
The rockers LOOK identical to the FE adjustable and say C3TE-6564-A
Are the FE and 534 rocker arms interchangeable?
It's either a 534 or MEL 430 setup, can you tell me which??
  #2 (permalink)
Old 11-02-2006, 09:00 PM
Got my own answer, C3TE-A rockers are 401-477-534.
Somehow I have on hand a brand new pair, shafts, stands, springs, rockers both sides.
I still dont know if the rocker arms would fit the 406/427 FE, they sure look the same....
I don't have a 534 so otherwise I don't have much use for em.
Nice setup though, factory end stands!
Tags
406, 534, 6564, 6564a, adj, arm, arms, c3te, engine, ford, mel, rocker
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
