Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-28-2006, 02:02 AM
Power_age Power_age is offline
Garage is empty, add now
Power_age is starting off with a positive reputation.
Engine VIN or engine number location
Hi folks!
A friend that I made through internet has an F150 with 4.2 V6. Heīs trying to find the engine VIN or engine number without luck.
Anyone can tell me where is located that stamped number onthe engine block?
Regards,
Mariano
  #2 (permalink)
Old 10-28-2006, 02:33 AM
bokker bokker is offline
bokker is starting off with a positive reputation.
hi, the vin number on my truck is found by looking at the lower of the front windscreen, from the outside of the truck. i had to use a light to be able to read it clearly. hope this helps. bokker.
  #3 (permalink)
Old 10-28-2006, 06:43 AM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.
Yes, that's where it is.
It's inside the cab, on a plate mounted to the top of the dash. You have to look thru windshield to see it.
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
  #4 (permalink)
Old 10-28-2006, 09:51 AM
Drizzt's Avatar
Drizzt Drizzt is offline
Drizzt is starting off with a positive reputation.
I think he may be confusing VIN with block casting numbers
__________________
2004 Ford F-150 SXT 4.6L 4x4
1986 Ford Ranger 5.0 H.O.
  #5 (permalink)
Old 10-28-2006, 10:58 AM
Sprry, but Imīm talking about the engine number, not the code no the VIN. I hve a pair of 302, it has a plain area (or plain boss, donīt know the correct term in english) to identify that block.
V6 has some similar area where some numbers on fabrication plant could be stamped?
Thanks for your answers,
Mariano
Tags
2000, 38, codes, engine, ford, fords, id, location, model, motor, number, numbers, ranger, truck, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. FordŪ is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
