Cold weather power loss/hissing
On three different mornings, my 2000 f-350, sounded like it's hissing on passenger side underhood. Happens when under slight acceleration, but loses power when held at that speed. If I speed up, it runs fine. Also, runs fine after a few miles and is warmed up. Only noticed when ambient temp is below 50 degrees. One morning it was 43 degrees outside, cranked truck to warm it up, and noticed hissing sounded as if it was coming out tailpipe also. Revved engine and let it idle again and sound was gone. It has the Superchip programmer installled. Also, noticed that it smokes when first started about half the time. Whitish smoke sometime worse than others. Any ideas?
There should be a sticky about this. It's that time of the year again, cold engine operation. That is normal, and it is a device called the Exhaust Backpressure Valve that closes when the oil temperature is below 140*, to help heat up the engine. It is a valve that closes off about 90% of the exhaust flow, and creates a power loss and a hissing noise in the exhaust, again in the right side. It is normal, either deal with it, or unplug the connector below the turbo in front, down center of the intake.
thechainsawman
11-15-2016 10:46 AM
SageofHalo
2004 - 2008 F150
06-20-2014 06:04 AM
stroker"1"
02-25-2005 06:33 AM
