Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 10-27-2006, 07:01 AM
ponch37300 ponch37300 is offline
Garage is empty, add now
ponch37300 is gaining momentum as a positive member of FTE.
propane injection
I would like to look into a propane injection system. Are there any harmful sides to it or can my 7.3 use it without any problems? Is there a particular brand or setup that you would recomend or have had good experience with? I guess any advice would be helpful to me right now since i don't know much about it. Thanks
__________________
2003 superduty cc 4x4 7.3, 5" mbrp exhaust, kwik filter, dp tuner chip, 6.0 intercooler, bts valve body, isspro gauges
2000 f-150 5.4, 4x4 off road package, project truck
  #2 (permalink)
Old 10-28-2006, 08:29 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Yes there are possible side effects, worst case scenario a ruined engine.
Your 7.3 can use propane injection, just like mine does. It gives me more hp and helps my ole 96 keep up with my friends that have NBS trucks with 7.3 L PSDs.
If you go with a vapor phase system like the Powershot 2000, and take the time to tune it properly, you greatly reduce the probability of problems.
Best advice I can give you call Dale at Tymar he really knows his stuff.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #3 (permalink)
Old 10-29-2006, 12:28 AM
CheaperJeeper's Avatar
CheaperJeeper CheaperJeeper is offline
CheaperJeeper is gaining momentum as a positive member of FTE.
I was thinking of doing a home-brewed propane injection for a bit more power myself. What I've been looking at is the Impco T-60 Beam regulator with the vacuum lockoff feature. This regulator is commonly used for running small to medium-sized generators - up to 60 HP - on propane.
The way the T60 regulator is designed it has a gas inlet port and a gas outlet port, but it also has a third port to control gas flow. The third port hooks up to a vacuum source from the engine's intake manifold and uses engine vacuum to meter the fuel. Higher RPMs=higher vacuum=higer rate of gas flow. Conversely as the RPMS drop, the vacuum drops and the flow of propane is reduced. No vacuum (engine off) and the regulator acts as a lockoff and allows no gas to flow from the outlet. Basically a demand-based metering system.
My idea is to hook the regulator up to my propane tank using a first-stage adjustable regulator at the tank, and the Beam T60 as a secondary regulator. For the actual injection part of the system I'm thinking of a pipe with orifaces installed in the air cleaner inlet to ensure it mixes well with the incoming air. With the adjustability of the Beam regulator, and the adjustable first stage regulator at the tank, I think I should be able to "tweak" it easily enough to get a decent performance boost without over-fueling and melting the engine.
Naturally I plan on installing an pyrometer to monitor EGTs and help me with the tweaking process. Anybody see any drawbacks to this idea?
__________________
84 Jeep Cherokee Chief 2-door 4WD - 4.3 Olds V6 diesel, 4.56 gears. Turbo coming soon.
84 Mercedes 300CD Turbo. Bone stock daily driver
86 F250 Super Cab 4x6 (dually), 7.3 Banks TURBO, SMF & ZF5-47, 4.10 gears, 3" Banks straight-pipe exhaust. Mileage unknown
  #4 (permalink)
Old 10-29-2006, 11:24 AM
Phydeaux88's Avatar
There is another current thread on this subject. If you are thinking of a Do It Yourself system you should read it, especially the post by pokerface5
here is the threads URL
http://www.ford-trucks.com/forums/53...on-system.html
__________________
Tags
beam, effects, ford, impco, injection, propane, side, t60, tuning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
