Help 2000 F150
Help 2000 F150
My Dad drives a 2000 F150, (I have an 04). As we were driving back to the office today both blinkers stopped working, his flashers and brakes lights are not working either. All the othe lights (head,running,third brake) are working fine. ANy help? Thanks all (first time poster here)
Brad
Brad
Originally Posted by memphisbrad
My Dad is having light problems in his 2000 F150. His brake lights stopped working along with hazards and brake lights. All othe lights seem to be working fine. Any help out there?
First time poster pround 04 F150 owner
BRad
BRad
Check for a bad fuse or relay, maybe. You might want to ask here <TABLE cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD></TD><TD></TD><TD>1997 - 2003 F150
</TD></TR></TBODY></TABLE>. Someone may have a wiring manual for your year. Good luck with it.
FOund it
The problem was (and seems to be fairly common) with the harness plug in the steering colum. There ia a pug that runs under the steerind housing. It looks like the use of the tilt wheel causes the prong that secures the male plug to the female plug receiver over time breaks and although it is connected it tends to back out and loose good connection. If anyone has this problem and needs to know how to fix it let me know and i'll be glad to help
Memphisbrad I have the same problem with my 2001 F-150.When I tilt my steering wheel downward my turn signal blinks fast on the front right and does not blink at the back right and also brake light not working right side.All this happens only when the steering wheel is tilted downward.All fuses are fine.Any help to fix this problem is appreciated.
Your Ford dealer should have a new hardshell connector in stock for about 10 bucks or so. It usually is more than just breaking the lock tabs for the hardshell to multifunction switch itself. It usually also breaks the tabs that hold the individual wires into the hardshell. Some of them I have found had all of the retainers broken in the hardshell connector. Just do a pin for pin swap into the new shell, plug it in and drive on.
Johns9163
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
10-07-2004 08:21 AM
