Dana Spicer Model 24 Question - Page 2 - Ford Truck Enthusiasts Forums
Old 04-18-2011, 08:28 PM
thx1138 thx1138 is offline
thx1138 is starting off with a positive reputation.
All this confusion seems to have been created by Ford.
Some of the part manuals (as NumberDummy stated) only show the 205. I have an exploded view from Ford (dated Jan 75) that IS the Dana24 but does not ID it that way. (the 203 and 205 both have a large ribbed cover on the back of the front output shaft) The diagram can be found here: http://www.fordification.com/tech/im..._64-72F250.jpg
(I'm not sure if I'm allowed to post it here)
The Ford issued diagram does state that this transfer case was used in 64-5 in the F100 and 64-72 in the F250.
It looks (to me) like someone at Ford writing manuals saw
"chain drive t-case = 203"
"bronco t-case = Dana 20"
"gear drive 1-speed = Dana 21"
"gear drive 2-speed = 205"
and completely missed the Dana 24. Aftermarket suppliers rarely double-check the OEM.
Jim
Old 04-26-2011, 03:22 PM
george5121 george5121 is offline
george5121 is starting off with a positive reputation.
Quote:
Originally Posted by MARC View Post
this may muddy the water a bit
I have a 59 f100 that has a spicer 24. Growing up I was told that Ford made 1/2 ton trucks and 3/4 ton trucks, etc, but they also had f100 heavy half listings. I do know that the spicer 24 was delivered to my dad with the 24 in it, it has never been replaced. Anyone have any input on this transfer case linked up to a 4bt cummis approx 120 hp/300ftlb torque?
Most of the confusion is people do not seem to understand that ford did not produce these. prior to 64 they were an option installed by the dealer. Today options are factory installed. Options use to be things the dealer installed after they ordered your truck and such dealer installed options do not appear in ford part manuals.
Old 05-12-2011, 11:47 AM
Early Ford 4x4
George,
You are partially right. Ford began building it's own 1/2 & 3/4 ton 4x4's in 1959.
Before that, they were converted by an external company (Marmon-Herrington) and sold through the dealer or a 'kit' could be purchased from Marmon-Herrington by a dealer (to be installed by the dealer). This conversion process worked much the same as it still does for ambulances, hearses, early crew cabs, schoolbusses and other special body styles. Marmon-Herrington continued building F-350 and larger 4x4's until a later date (possibly '64 ?? anybody else know?) I think they still do Ford's conversions on 3-ton and larger trucks.
Ford mechanics still had to maintain these. Unlike body conversions authorized mechanical conversions (4x4) were documented so that they could be repaired. Even as NumberDummy (THE Ford Parts God around here) has said the official books list the NP203 & NP205 as the only transfer cases used. This is simply not true. The text and pictures don't match, if you read up further you'll find a link to an exploded view dated '74 that IS a Dana/Spicer 24, but it's not labeled as Dana/Spicer part. I stand by my statement that Ford created this confusion.
Jim
ps: NumberDummy you rock !! Unfortunately, not all parts guys are created equal and some believe those parts books were chiseled on stone tablets by the infallible hand of Henry Ford himself. A parts manager near me came just short of calling me a moron because tried to get parts for this "non-existant" transfer case. ND, your efforts have helped me and many, many, MANY others get info we never would have found ourselves. And the internet preserves this info for others who will hopefully continue to fix, rebuild and play with our toys long after we're dust.
Old 11-03-2011, 07:30 PM
croweyes croweyes is offline
croweyes is starting off with a positive reputation.
dana 24
since were talking dana 24's, does anybody know the shift pattern?
Old 11-04-2011, 12:41 AM
FRONT
4L
N
2H
4H
Old 09-21-2013, 10:47 PM
mont974x4's Avatar
mont974x4 mont974x4 is offline
mont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to beholdmont974x4 is a splendid one to behold
subscribing.
Old 01-03-2014, 12:47 PM
chetspencer's Avatar
chetspencer chetspencer is offline
chetspencer is gaining momentum as a positive member of FTE.
So I found this thread searching for seals for my original 1959 DANA transfer case whice Mr. NumberDummy so accurately states above that it's listed as a Model 205. Well we all know it's a DANA 24, so to end the confusion I present this picture I took yesterday.
Now you know the rest of story.
Old 01-03-2014, 02:16 PM
iggybob44's Avatar
iggybob44 iggybob44 is offline
iggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant futureiggybob44 has a brilliant future
Back in the late 50's.....The NP205 didnt even exist........Im not even sure when New Process began making ANY transfer cases. Before the 205, they built a NP200, NP201, and NP202.......Ive owned several older IHC 4x4's, my 1966 1200A and a 1970 1200 Travelall both had the 202, which was a single stick box similar to the later 205, and i had a 66 Dodge W200 with a 201, which was two stick kinda like the old Dana/spicer 18 that was used in jeeps and early IH scouts.......it seems to me, if i recall correctly that the Kaiser Jeep M715 Ton and a Quarter used the NP200.........the numbers unfortunately dont necessarily follow a logical chronology, since the chain drive, 2 speed full time NP203 was produced after the 205 was already in full production.
GM used a Rockwell T-case before switching to a mixture of Np 205 and Dana 20's around 1969 or 70.....the rockwell had straight cut gears and made a distinctive gear whine noise, and i have heard that Rockwell equipped some Fords as well
Old 01-03-2014, 07:46 PM
The confusion was due to the Ford #300205
Check the lable in the pic and you'll see what I mean.
Old 01-04-2014, 06:01 PM
iggybob44's Avatar
That could very well be, Chet! the Bill of materials number does have a 205 in it.......Worse still, what if the guy just figured the Serial Number meant something, then you have a T18
Old 01-11-2014, 10:54 AM
lee lee is offline
lee is starting off with a positive reputation.
Not to high-jack this thread but....
My ole 24 leaks like a siv and occasionaly pops out of gear. I researched rebuilding it then read that the 205 will bolt right in it's place.
Keep'un an eye on CraigsList I found a 205 from a 1976 F250 for $100. I plan on rebuilding it an installing this spring.
Just another option for this thread.
Lee
Old 01-13-2014, 08:42 PM
Lee
Thanks for sharing the interchange info. Does your Dana 24 pop out in 2H or some other position? Mines has never popped out of gear but I haven't had a chance to try try 4H or 4L. Otherwise it just leaks a lot.
  #28
Old 01-14-2014, 07:48 AM
lee lee is offline
Hi,
I have only had it pop out in 2H.
Trouble is that I can't get it back in gear until I come to a complete stop. (Non-Sync). Really sucks when it happens on the highway while pulling my RV
  #29
Old 01-14-2014, 08:15 AM
Hi,
That sucks. Maybe the shift detent needs adjustment?
I just came across a trick to use 2 seals instead of one on the input/output shafts. One to keep the oil in and one to keep the dirt out. Not sure if you can use original seals though. I also read that people are using sealed bearing as an upgrade.
  #30
Old 02-27-2016, 03:44 PM
missmodel12 missmodel12 is offline
missmodel12 is starting off with a positive reputation.
One thing that was not mentioned about the change of the Dana 24 to the New Process 205 is the gear ratio difference. I am sure that there are other changes throughout the production run but here is what I have found through my shop and my comprehensive Ford Shop Manual and Factory Parts books. I am a numbers dummy as well as a master mechanic having worked on these. 1959 to 1964 1/2 and 3/4 tons used the Dana/ Spicer 24 two speed transfer case. 1965-1976? F100 used the Dana/ Spicer 21 single speed transfer case. Just hi range 1 to 1 gear ratio. Broncos used the Dana/ Spicer 20 with low range at 2.4 to 1 in low range. ( I installed a set of OBrian (sp) gears in my 67 Bronco for 4.88 to 1 in low range) This is the first generation Bronco. The F150 used the NP 205 and was not divorced. The two speed transfer case was one of the differences between the F100/F150. The 1965-72 F250 used the Dana 24 changing to the New Process 205 in the new body style 1973 F250. Some say that 1972 has the 205 and possibly some late ones did but I have not seen one personally. The low range in the Dana/ Spicer 24 was I believe 1.86 to 1 and the 205 is 2.0 to 1. I am away from my notes in Mexico and doing this from memory. I have access to the Ford parts books and illustration books from 1959 to 1976 for sure and possibly the early 2000s.
WTB - Dana/Spicer 24 Bearing Cover thx1138 WTB - Parts & other 8 10-06-2015 12:33 AM
64 F250 4x4 Dana 24 Transfer Case wildwindjerry 1961 - 1966 F-100 & Larger F-Series Trucks 5 04-20-2015 01:57 PM
57-60 what is it? hooligan24 1948 - 1956 F1, F100 & Larger F-Series Trucks 72 04-07-2008 04:39 PM
63 to 78 F250 4x4 drivetrain swap Brad 61 1961 - 1966 F-100 & Larger F-Series Trucks 4 02-17-2005 08:45 PM
Dana/Spicer,60 oleblue70 Offroad & 4x4 3 01-29-2001 11:05 PM
Tags
21, 24, 79, case, dana, exploded, ford, installation, instructions, kit, model, parts, rebuild, transfer, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
