Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-26-2006, 07:03 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Jesus spoke a lot
1999 Ford F-550
Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future
Don't forget a BTS valve body for your transmission if you have an automatic.
www.brianstruckshop.com
I'm at work right now, I'll come back later on and tell you more, but everyone before me has covered a lot of good ground for you.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
God and Dog
  #17 (permalink)
Old 10-26-2006, 07:04 PM
Jesus spoke a lot
1999 Ford F-550
HX crossover lines for the high pressure oil rails.
__________________
Dan
God and Dog
  #18 (permalink)
Old 10-26-2006, 07:14 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
2002 Ford F-350
PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold
People have all stated their opinion, so i will state mine too. They all have the same logic, more air in, more air out, and less EGT (exhaust gas temperature).
If you gave me $2000 and said "Here, modify it" this is what i would do. Prices indicate that you install them. or, bring it to me and i would gladly do it for you
-Intake filter- www.fleetfilter.com part 46637($20) or Napa part number 6637-($40)
-Exhaust- Mark Romriell (MKO Diesel performance) 5" exhaust, muffler-less or with a muffler, about $350 shipped, very reasonable in price. Look on ebay for this guy.
-Gauges- If you are good at wiring, you can get the kit and do it your own, all of the wiring and painting of the pod. Kits usually cost $300-350, or if you want to have them ready to slap on and hook up, you can get them pre-wired and all for about $400. Ill figure $400 into the price. I personally prefer the brand of gauges -Autometer, but there are others like DiProcol, Isspro and Spa digital gauges. The common three parameters are EGT temp (pre-turbo), transmission temp, and turbo boost. I bought my gauges from Garrett @ www.puredieselpower.com
-Now you have the ability to get air in and out and monitor the temperatures, it's time for a chip. The man to call for chips is Jody Tipton at www.Dp-tuner.com, he can set you up with a fully customized chip for YOUR truck and yours only. It is much better than a generic tuner or fueling box, such as Edge, Superchip, Bully Dog, and Diablosport. His chips range from one single file for $239, to a an amazing 16 position chip with every imaginable tune on it, for about $40 more per tune. I myself am going to get rid of the TS performance chip i have now, and get a DP tuner 8 or 9 position chip. so, lets say that a 6 position chip will cost around $450. You still have around $750 left after shipping. Want to keep going?
Read on.
-Now you will probably enounter some problems such as throwing a code when you really romp on the pedal. The Powertrain Control Module (PCM) thinks that the truck is running a stock program still, so it sees an abnormally high boost level, and it will throw a code. The fix for this is to go to www.itpdiesel.com, and buy a Overboost Regulator. It is about $45 or so, and it will get rid of this problem.
-Due to that chip adding more power to the engine, it has to force that power through the same transmission, that is not designed to handle the extra power. Call up Brian at BTS (brianstruckshop.com), and set up a custom-made transmission Valve Body. They run about $225, and if you tell Brian that you are running a Tipton chip, he can modify it custom for that chip. Also, tell Jody that you will be getting a BTS valve body (here we commonly call it a "BTS VB"), and he can tune the chip for the VB as well.
-A comfort mod is next, not one that produces power, but it makes the engine run smoother and quieter. there is a thing that is called a Stainless Steel High pressure Oil rail Crossover. It is a tube that adjoins the two oil rails (oil that is used to fire the injectors, 500psi-3000psi), and it acts as a shock absorber to make all 8 cylinders have relatively the same pressure. It is more expensive than a rubber version, but it's going to last forever, it's about $70. I believe you can get that at ITP when you buy that overboost regulator.
-Another comfort mod is to eliminate the quick-disconnect fittings on the suction-side of the fuel pump. The factory design has a crappy "mixing chamber" inside the tank, that lets air in the fuel, and the air in the fuel will cause the injectors to become louder, and it also shortens their life. Removing the Q/D's will also help prevent air from entering, as they work well under pressure, not so well under a suction. I believe this $40-70 mod can be purchased at ITP as well, a filter will be about $105 if added to the kit.
we have about $350 left.
-Your stock compressor wheel in the turbocharger will probably be hating life, as it tends to reach it's limit very quickly on the air it can push out of the turbo and into the engine, and it will shoot that air back out of the compressor, commonly called "surge". a cure for this is to install an aftermarket compressor wheel, designed to reduce or stop surge. it can be found cheapest at www.xtremediesel.com, for about $55.
While you are spending all of this money, i thought it would be nice to do some free or really cheap mods:
-rerouting the crankcase vent (CCV) to the atmosphere. the stock system reroutes this into the intake of the engine, and it's a dirty mess, as oil will seep out of the intercooler boots. You can do this mod for about $15, and the only thing i needed was a piece of 4" exhaust pipe, about 4" long, to replace the piece you remove. To get the gasses away from the engine, run a piece of 1/2" heater hose to whatever length you want it. I grew tired of the infamous cloud of mist coming out from under the truck, so i tied mine into my stacks. Look at the connector that is between your two rubber intake boots between the air filter and the turbo, you'll see what i mean.
Also, a FREE mod is to remove the foil on the driver's side intercooler pipe. It helps that whistle get a little louder, and it has no adverse affects. Disclaimer: it's a royal pain to get that stuff off. Let's spend some more money.
Some things that you want to keep track of, are transmission temps, and EGT temps. the transmission can get hot, so if you browse Ebay, you can get a 6.0L's transmission cooler (NEW) for about $100-125. installation is easy, several guys here have done it. The stock transmission cooler on these trucks sucks. I believe it is about the size of a keyboard. This new one is three times that size.
To reduce the EGT, a wise decision is to install another 6.0 part, this time an intercooler. It's a direct drop in, and some guys see a reduction in EGT of 100-150*, for about $100-150, again off ebay.
Well, i think this about depletes your fund. You will be out $2000, however the benefit in performance, and the massive grin on your face all the time is well worth the cost.
__________________
2002 F-350 Thats been nothing but a waste of time and alot of money!
  #19 (permalink)
Old 10-26-2006, 07:24 PM
powrstrkn''s Avatar
powrstrkn' powrstrkn' is offline
powrstrkn' is starting off with a positive reputation.
I ditto Kris' beastly post
but he did for get the all important Zoodad mod
__________________
-Steve
99 F150 XLT S/C 4.6 4x4
99.5 350 PSD 4x4 4r100 xlt 3.73 LS
TS tunes, 6637, 5" cannon, autometers on the pillar
  #20 (permalink)
Old 10-26-2006, 07:26 PM
scooter80 scooter80 is offline
scooter80 is starting off with a positive reputation.
Fantastic write-up Strokin'. I have done the intake (AIS), chip (Edge for now) and the insulation removal. I think that's it for this season (other than a fuel filter after filling with B11 soon), but I've been looking to make a list of more mods for Spring. Thanks for the awesome info and taking the time to put it on "paper".
  #21 (permalink)
Old 10-26-2006, 07:41 PM
amiller93's Avatar
amiller93 amiller93 is offline
amiller93 has a good reputation on FTE. amiller93 has a good reputation on FTE.
Good break down Kris but whats he going to do next weekend?
Might want to consider some filtration also - coolant, oil bypas, Trans, ect
Coolant ~79
Oil ~250
Trans ~180
  #22 (permalink)
Old 10-26-2006, 09:32 PM
Jesus spoke a lot
1999 Ford F-550
Kris that post earned you some reputation points. Good work!
__________________
Dan
God and Dog
  #23 (permalink)
Old 10-28-2006, 08:07 AM
lakerats's Avatar
lakerats lakerats is offline
lakerats is starting off with a positive reputation.
Thanks to all for your sage advice. Kris - special thanks to you for the quantity of info and the explanations of not only what, but the how and why. I'll start as you say by helping the engine "breathe" better and easier.
I think we can now put this thread to bed.
Clif
Spicewood, TX
  #24 (permalink)
Old 02-16-2008, 05:34 PM
DR JOE DR JOE is offline
DR JOE is starting off with a positive reputation.
Thanks Kris.... What a list... Plan to do what I can as the money flows my way...
Doc.
__________________
2001 F-250 Crewcab 7.3 Auto 4X4.
Add on's 6637 air filter mod, Full 4" exhaust and a Bull Dog chip set at 65 hp.
TIRE SMOKIN, NOS PURGIN AND TURBO'S SCREAMING THAT IS PMRA DRAG RACING.
  #25 (permalink)
Old 02-17-2008, 01:54 AM
jtharvey's Avatar
jtharvey jtharvey is offline
Lost Soul
jtharvey is a name known to all jtharvey is a name known to all jtharvey is a name known to all jtharvey is a name known to all jtharvey is a name known to all jtharvey is a name known to all
Quote:
If you gave me $2000 and said "Here, modify it" this is what i would do. Prices indicate that you install them. or, bring it to me and i would gladly do it for you ....
Nice post Kris. I agree with everything you've said, but I personally would go with an ATS intake housing over a WW. That would put you slightly over budget, but IMO is the better cure for surge when compared to the WW.
__________________
Jeremy
See My Webshots for pics.
  #26 (permalink)
Old 02-17-2008, 02:07 AM
nhill2090 nhill2090 is offline
nhill2090 has a good reputation on FTE. nhill2090 has a good reputation on FTE.
this thread is almost a year and a half old...
__________________
Nic
1999 (early) F250 XLT SC LB 4x4
6" lift, 5" exhaust and a BTS trans. That sums most of it up.
PAA Member #1
  #27 (permalink)
Old 02-20-2008, 08:11 PM
ToughBuiltFord ToughBuiltFord is offline
FTE Sponsor
ToughBuiltFord is starting off with a positive reputation.
Quote:
Originally Posted by EWALR1
The Stock Exhaust Is Restrictive And An Aftermarket One Would Get Exhaust Temps Out. And An Afe Intake Is The Better Of Them All.
a i second the afe
http://motorhaven.autoanything.com/a...A2114A0A0.aspx
__________________
Motorhaven powered by AutoAnything Auto Parts
Since 1979 - Equip Any Vehicle For Any Lifestyle
Use the coupon code FTEDEAL in our shopping cart and get $20 off orders over $199
Check out the AutoAnything blog for the latest news in the Automotive industry!
Got an Automotive Blog? List it here in the Auto Blog Directory!
  #28 (permalink)
Old 02-20-2008, 08:23 PM
bdrummonds's Avatar
bdrummonds bdrummonds is offline
Maximus Overdrive
1999 Ford F-250
bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of
Quote:
But it is still relevant.
__________________
Brandon
PAA MEMBER # 7.3, 99.5 CC,4X4,SB, leveled,live tuned by Jody,1.15 van turbo w ATS housing,6.0 IC,AFE big boost filter, Petes Armour, FASS/DFA fuel system,fuel bowl delete,black MBRP stacks, 02 headlights,F650 dash, and a bunch other stuff that wont fit in my sig. 293K and counting.
  #29 (permalink)
Old 03-05-2008, 08:30 PM
pekkah pekkah is offline
pekkah is starting off with a positive reputation.
no I didnt see your thing but that is what I was loking for.I found it once and couldnt find it again thank you very much.
  #30 (permalink)
Old 03-05-2008, 08:31 PM
ah got it thanks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
