Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 07-10-2007, 12:41 AM
mtford's Avatar
mtford mtford is offline
mtford is starting off with a positive reputation.
I have a similar sounding prob. but mine only does this hot. Idles a little high (900-950) and shakes like missing some cylinders. Also touchy throttle and blows soot/smoke much easier with less throttle. Pulled two codes 1211 and 0603. Ok cold. Oil changed 1000 miles ago running rotella synthectic. New napa 6637 filter 1500 miles ago. Just changed fuel filter and add some fuel additive two days 150 miles ago.
  #32 (permalink)
Old 11-17-2007, 06:37 PM
Loadre's Avatar
Loadre Loadre is offline
Loadre is starting off with a positive reputation.
Just changed the oil with Delo (which I had been using) and a new fuel filter yesterday. It sat overnight and was about 40* this morning, romped when I started it for the first time and I pressed the peddle and it went away. Went to work and came out 7 hours later and it did it again. Only thing I did different yesterday was actually drained the fuel bowl before removing the filter, I usually just let it spill out.
  #33 (permalink)
Old 11-18-2007, 12:35 AM
mtford's Avatar
My rough running problem became a constant. Took it into a local diesel shop that said they thought o-rings but that it was rare at 55k. Then changed their tune and said oil press reg. for injection and replaced it which got the press. from 400-1200 psi to 500-1200 psi. Then said that the DME (main engine computer) which i believe is driver side fire wall area was bad. DME fixed it and its been ok for last 5k.
__________________
1960 f100 4x4 all orig. --2000 f350 Lariate PSD 4x4 crew,super chip programer, 6637 ,minor lift ,air tank system with bags and horns
--2002 Excursion Limited PSD 4x4,6637, super chip programmer, minnor lift.
  #34 (permalink)
Old 05-10-2008, 06:32 AM
mastertech2002 mastertech2002 is offline
mastertech2002 is starting off with a positive reputation.
reply to morning romp romp
hello all ive come across the morning romp romp myself on a few of my ambulances 7.3 auto trans and found fuel leaks to be the cause...
Hear me out... IF the locks have been removed from the fuel lines they will start pumping back and forth on the hard line to the frame. This over time will collect dirt. and the dirt will eat the Orings in the fuel lines like sand paper..
sucking air into the system... Also you might wanna check your lift pump...
you can use a small mirror to look at the underside of the pump ...and as your humped over your engine place the mirror down into the valley and look up underneath the pump it has 2 small holes that start to leak ...if the pump fails
the upperhole will leak fuel the lower oil... if it leak romp romp romp
  #35 (permalink)
Old 05-10-2008, 07:24 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Jesus spoke a lot
1999 Ford F-550
Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future Kwikkordead has a brilliant future
Welcome to FTE Mastertech2002.
It sounds like you are talking about the older style engine in the 94.5-97 body style with the mechanical pump in the valley of the engine.
The 99-03's have a Bosch pump on the frame rail and your fuel connector o-ring theory would be a good one for that one too. Those quick connects will let a LOT of air into the system.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, all stock.
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
God and Dog
  #36 (permalink)
Old 11-19-2008, 01:41 PM
dief_167 dief_167 is offline
dief_167 is starting off with a positive reputation.
fluctuating idle
I my self are having that same idle problem with my 7.3. but i have also done my first oil change but i put a gal. or lucas could this cause the problem with the ruff idle.
  #37 (permalink)
Old 04-19-2009, 08:47 AM
bearman113 bearman113 is offline
Chapter ******
bearman113 is starting off with a positive reputation.
Mine does it every time I start it until it warms up. Oil change every 3000, sensors replaced in December. Any other ideas will be helpful
__________________
Eric 2000 F350 CC SWB SRW 7.3 no mods yet
  #38 (permalink)
Old 04-19-2009, 08:55 AM
megawatt00's Avatar
megawatt00 megawatt00 is online now
megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future
Quote:
Quote:
The easiest cure for the romps is to use syn oil and not dino. When I was using Rotello Dino in my truck I would get the romps when it was cold in the morning. I switched over to Rotella Syn and the romps went away. The truck runs much quiter now also. Do not add any additives to the oil what so ever. I would drain that oil out as quickly as possible. Our trucks run on high pressuer oil to fire the injectors and adding additives is not good. Lucas actually foams up Take a look at this
What about Additives?
__________________
Jim
2001 F350 4X4 DRW
Bilsteins, 4" Turbo Back Into 6" Stacks, 6637 w/,Custom Cold Air Intake ,Autometer guages, DP TUNER
http://www.roadsidehelpnetwork.info/
PAA # 14
RIP Mark.. I'll never forget you!!
  #39 (permalink)
Old 04-19-2009, 08:58 AM
Chapter ******
Thanks Jim, The only adds I put in her are in the fuel system over 200000 miles and not sure the injectors have been replaced. Those will probably be the next thing done.
__________________
  #40 (permalink)
Old 04-19-2009, 09:16 AM
megawatt00's Avatar
Your welcome Eric. The other poster had put the Lucas in. Try running Syn and see if that helps it out. If I used the block heater I wouldn't have the romps with dino either. But where your in the North Pole a combination of the block heater on a timer and Syn oil will help you out.
__________________
Jim
2001 F350 4X4 DRW
PAA # 14
  #41 (permalink)
Old 04-19-2009, 10:10 AM
Chapter ******
Don't use a timer, plug it in and leave it, never know when you have to go somewhere. Have been running synth also didn't start the romp romp till about a week ago.
__________________
  #42 (permalink)
Old 04-19-2009, 10:20 AM
megawatt00's Avatar
Here I use the timer the electric rates are some of the highest around! Make sure that your block heater is working also.They rarely fail but the cords on them do.
__________________
Jim
2001 F350 4X4 DRW
PAA # 14
  #43 (permalink)
Old 04-19-2009, 10:22 AM
Chapter ******
Check the cords in the fall b4 snow flies and several times during the winter. Just a little worried as the romp romp is a new thing for my truck
__________________
Tags
2001 , 2005 , 73 , f150 , fluctuating , ford , idle , irregular
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
