Other benefits of biofuels - Ford Truck Enthusiasts Forums
Old 10-25-2006, 10:19 AM
eigenvector's Avatar
eigenvector eigenvector is offline
eigenvector is gaining momentum as a positive member of FTE.
I was thinking about this last night. CO2 is one of the prime concerns in global warming, its one of the things that man produces in abundance. In using biofuels, that is plant based fuels, would we not be helping that problem at the same time? Consider this, plants typically produce their energy by consuming CO2 and H20, with O2 as the byproduct. We burn that fuel using O2 to produce CO2 and H2O as the byproducts. Obviously the equation isn't balanced and we produce far more CO2 than plants consume, but by using plants to produce our fuel aren't we perhaps drastically reducing the amount of excess CO2 produced every year?
Old 10-25-2006, 01:21 PM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
In theory and in paper -- maybe. In practice -- not as much as you'd think. I'm not familiar with bio-diesel so this may not apply to that, but when making ethanol, one need quite a bit of heat for distillation, and if that comes from a fossil source, you only move the source of CO2 emission to someplace else.
I know Bush got ridiculed for hydrogen, and even here many people don't have a good opinion about H2, but one way to drastically reduce C02 emission is use hydrogen as a fuel in IC engines while generating electricity with nuclear power or with some enviromentally friendly renewable source. (wind or solar)
Another is to have more electric cars. Most peiople's daily commute is well within the range of today's electric cars (100 - 150 miles).
Old 10-25-2006, 06:31 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
A lot of ethanol do not rely on fossil fuels for heat. They use other plant byproducts.
When we burn fossil fuels, we release carbon that was stored in the earth for hundereds of millions of years, and would naturally take a very long time before it ever reached the atmosphere. Essentially, we're adding new carbon to the atmosphere. With biofuels, the plants intake CO2 as they grow, releasing O2. When we burn the biofuels and plant matter, the CO2 is released, to be soaked up again with next years crop.
I guess it comes down to, what is more efficient? A solar cell, or a leaf? I'm guessing the leaf...
Old 10-26-2006, 01:49 AM
Quote:
What byproducts?
You guessed wrong. The solar cell is significantly more efficient than the leaf, though it may not have many of the additional benefits the leaves may provide.
Old 10-26-2006, 10:51 AM
PSKSAM2's Avatar
PSKSAM2 PSKSAM2 is offline
PSKSAM2 is gaining momentum as a positive member of FTE.PSKSAM2 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by aurgathor
What byproducts?
I assume he is referring to things like bagasse for sugarcane (what is left when the sugarcane is crushed for it's syrup) or lignin when you are talking about switchgrass and other cellulosic ethanol feedstocks. These can be used to fuel the ethanol production process. Most US ethanol is not made with these, though the future looks bright for switchgrass taking over for corn.
-Jim
Old 10-26-2006, 10:54 AM
My understanding of sugar cane processing is that they can practically power nearby towns with all the excess energy the bagasse provides.
Old 10-26-2006, 11:06 AM
Yes, bagasse is apparently sufficient when making sugar; however, I doubt that's enough when making ethanol that require at least 2 additional distillation steps. (that Pimental article lists 3, BTW) Now, if someone figures out some tricky way to separate ethanol from water, then it would be all different.
Corn may be a different since it has more burnable waste and less sugar. (starch, to be precise)
Is our lobby not big enough? chevenstein General Diesel Discussion 19 02-24-2015 12:45 AM
Food for thought, or perhaps, no food for thought... quaddriver General NON-Automotive Conversation 23 06-09-2014 11:50 PM
Ford Scales Back Production of Trucks and SUVs haulingboat 1999 - 2003 7.3L Power Stroke Diesel 6 05-21-2008 12:04 PM
Brazil to make BioD form Sugarcane...and not kill any more forest haulingboat 1999 - 2003 7.3L Power Stroke Diesel 17 04-28-2008 10:32 AM
Ford to produce 3V 4.6L DeckedoutF150 2004 - 2008 F150 6 03-16-2004 04:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
