Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-25-2006, 05:59 AM
norvillebob's Avatar
norvillebob norvillebob is offline
Garage is empty, add now
norvillebob is starting off with a positive reputation.
390 timing mark location
Hey folks,
I'm in a spot here and hope someone can help me out. How far away from the "0" mark on the pully is 10 deg BTDC. I can find the "0" but no other markings on my pully(internally dampened right?). Is it an inch or the length of a 1/4 dollar, nickle,,what ???? I need to set the base timing so I can adjust the carb and idle. Most seem happy with about 10deg btdc.
I was told by the PO I have a 1964 390 from a demo t-bird.
thanks
bob
  #2 (permalink)
Old 10-25-2006, 07:31 AM
RapidRuss's Avatar
RapidRuss RapidRuss is offline
FE "Freakin Expensive"
RapidRuss has a great reputation on FTE.RapidRuss has a great reputation on FTE.RapidRuss has a great reputation on FTE.RapidRuss has a great reputation on FTE.
Best I can tell on mine in the cold dark with a flashlight its about a 1/2" away from TDC..
RJ
__________________
Blue Saphire 70 F250 436"CJ in Progress/Rollerized C6/4:10 Locker
Teal and Silver 96 XLT F150 4X4 302", EAOD, 3:55 Trac-Loc, Lock out Hubs, Daily Driver
Vista Blue 07 Mustang "Pony" 26K on the clock
  #3 (permalink)
Old 10-25-2006, 07:42 AM
Thanks, RJ. That's what I'm looking for.
bob
  #4 (permalink)
Old 10-25-2006, 10:56 AM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
Get an adjustable timing light and you can use 0°, TDC for all your timing. I have never seen or heard of an internally dampened FE. I have however, heard of a dirty damper so you can't see the marks. I don't think I ever saw a factory damper without at least 10° marked and most have 30° marked.
  #5 (permalink)
Old 10-25-2006, 12:04 PM
HMM , well perhaps I'm wrong. To me it just looks like 2 seperate pully wheels bolted together. I'm new to FE's.
So anyway. I think my mark is way off. It reads about 20deg to the passengers side or down side. When I get it closer to "0" CCW is retard and the closer I bring it to "0" the worse it gets. and Then I get the "hot start" issue and then it diesels. If I keep it about 20 adv?? it starts nice and no over-run. ???
The Vac adv is plugged. and I cannot find any vac leaks. At low Idle it's about 16Hg then 20Hg at about 1k rpm. The Edelbrock is set at 1.75 turns out. Engine was about 180+190 temp.
Any ideas?
  #6 (permalink)
Old 10-25-2006, 12:21 PM
Bear 45/70's Avatar
So check the TDC. Pull #1 plug and get the piston as close to TDC as you can and check the mark.
  #7 (permalink)
Old 10-26-2006, 06:27 AM
update
I found the marks and yes I was reading it bass ackwards.
Still. It seems to like 22deg that seems high. If I try to bring it in I get clatter and hard starts. Can this be correct? Am I not using enough idle screw on the carb. Could the PO have the cam degreed? +/- . I pulled the No 1 plug and it seems correct with the mark on the wheel. I'm lost here. I was running out of light.
I can get it to idle OK in park @ 650/700 rpms but then in gear it stalls. So If I bump the idle to 900 in park it'll hold 600/650 in gear but it wants to take off on me.
Could this be a vac leak I cant find??? My manifold is vibrating between 16 and 19 Hg
I'll have to pull #1 again and check it. Is there any reason the timing could be so high??
thannks
bob
  #8 (permalink)
Old 10-26-2006, 07:44 AM
Redmanbob's Avatar
Redmanbob Redmanbob is offline
1964 Mercury Comet
My Garage
Redmanbob is gaining momentum as a positive member of FTE.Redmanbob is gaining momentum as a positive member of FTE.
Mine was doing a similar thing on me. As instructed I tried running it off the man vac line just to see. got it to idle 850 @10ē like that. switched it back to ported to see what it would do and it was ok with a slight idle adj.. ?? seems to like 12ē a little better but we'll let some time pass as it's a fresh build.
http://www.centuryperformance.com/vacuum.asp maybe this will add some advise on the vacuum...
__________________
66 F100 352FE / Cruiso
71 F250 360FE /C6
CRATE = Cant Really Appreciate The Engine..
  #9 (permalink)
Old 10-27-2006, 06:20 AM
Just a quick up date.
The timing is set at 15btdc I hade to crank the idle up some. TDC is TDC I rotated the enging and man that piston comes up high in the hole.
So, I'm thinking I'v got a vac leak somewhere?? I replaced the booster line, the dist line, the manifold vac line, and the short line from the manifold to the hard line to the tranny.
I hosed down everything around the carb and vac lines with carb cleaner. Is there a soft vac line at the tranny??? Or the modulator?????
It''s idle is at 850-900 and drops to 600-650 in gear and doesn't surge in gear anymore but it's still not right.
the vac measured from the manifold port at the carb "vibrates" from 11 to 17 at idle. But give it some gas at she sits rock solid at 20hg???? Edlebrock 1405
Thoughts???
Hey Bear, I have a siamese mauser in that cal. one of my favorites.
  #10 (permalink)
Old 10-27-2006, 07:26 AM
RapidRuss's Avatar
Just a quick note...Is the carb tight to the intake?
RJ
__________________
  #11 (permalink)
Old 10-27-2006, 08:07 AM
RJ, Best I can tell. I poped the carb off and the gasket was dry/clean and like new. I won't overtighten it cause I've broken ears before. There was no change. I think I'll stop but the parts store and pick up a new one anyhow. They are cheap.
I do know the PO had this carb off the truck for a year or so and running on another vehicle. That gasket is a good place to focus. I really thought the carb cleaner would bring that out.
thanks,
bob
  #12 (permalink)
Old 10-27-2006, 08:11 AM
Redmanbob's Avatar
1964 Mercury Comet
My Garage
I think it was Bear on another thread that mentioned using an unlit propane torch turned up just enough to hear it. Run it around the intake edges and carb base, other areas of concern and listen for a change in RPM..
__________________
71 F250 360FE /C6
  #13 (permalink)
Old 10-27-2006, 09:11 AM
RapidRuss's Avatar
Yeah the carb cleaner should have done the same thing..unless there making it different now? LOL..you know Ozone stuff?? LOL
RJ
__________________
  #14 (permalink)
Old 10-27-2006, 09:24 AM
RJ, I did think of that. It say's highly flamible. I'll try wd40. I don't like to use starting fluid.
bob
  #15 (permalink)
Old 10-27-2006, 09:31 AM
RapidRuss's Avatar
Ya..OH NO dont use starting fluid !!! LOL....you wont have to worry about the motor any more...LOL..
RJ
__________________
Tags
1964, 390, big, block, fe, ford, forum, location, locations, mark, marks, read, tbird, timing, timming
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
