Gelling temp for b20?
Old 10-24-2006, 09:55 PM
guthrie&co's Avatar
guthrie&co
guthrie&co is offline
Anyone know the gelling temp for B20?
Old 10-25-2006, 07:24 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
I live in northern Oregon, and run B-80 down to 0 deg, I don't think you'll have to worry about B-20 gelling where you live! I haven't seen any specs on B-20 gell point because I think it is a non-issue.
FABMANDELUX.
Old 10-25-2006, 05:57 PM
guthrie&co's Avatar
guthrie&co
sounds good!
Old 10-25-2006, 06:59 PM
cookie88's Avatar
cookie88
cookie88 is offline
Phydeaux is going to have to expain how that works. I don't get how a blend of #2 diesel, which gels just below freezing, and biodiesel, which gels slightly above freezing can have a gel point lower than both????
Old 10-25-2006, 07:28 PM
fabmandelux
I think you meant me, Scott
Here in Northern Oregon our fuel suppliers blend 15-20% Kerosene with D-2 for winter use. Our winter fuel is good to about -20F. Normal wintertime temps aren't usually that cold, BUT once in a while we get sub-zero weather. 2 years ago it went to 18 below and stayed there for 3 weeks.
FABMANDELUX.
Old 10-25-2006, 07:57 PM
cookie88's Avatar
cookie88
cookie88 is offline
Actually I did mean Phudeaux88. I was thinking there was some sort of chemical reaction that lowered the gel point when the two were mixed. I was going to have the resident chemist explain it.
Of course, now that I know your fuel is blended I need no further explanation. I appreciate you clearing that up
Old 10-26-2006, 08:20 PM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
Cookie
It's a little complicated to explain here but it has to do with the way molecules of a pure substance interact with each other during transition from one state (liquid) to another state (solid). When you mix in foriegn molecules you interfere with this interaction.
Thats why antifreeze works.
white Buffalo
90
10-27-2015 04:01 PM
Sarge261
02-16-2015 02:00 PM
white Buffalo
37
01-26-2014 11:06 PM
Rich in CO
02-02-2011 01:17 PM
renyren
11-18-2009 09:15 AM
Quick Reply: Gelling temp for b20?
