Wastegate Control Duty Cycle values
What kind of values should someone typically see for the Wastegate Control duty cycle percentage?
The reason that I ask is that I've been monitoring it with AutoEnginuity and on my 2000 F450 it's almost always either at 100% or close to zero %. Is that normal?
How is the Wastegate Control duty cycle related to such things as engine RPM, Turbo boost pressure and so on? In other words... when should the duty cycle increase towards 100% and when should it be close to zero %?
Crap Alan, you are quick with a diagram. I see there is a wastegate solenoid. Those are usually on or off. It will not activate the wastegate so WTH? Simply a sensor? Then why the name solenoid? Curiously, this solenoid is actually pneumatically activated and therefore a diaphram. I say it's on or it is off.
Originally Posted by amiller93
I dont think it is the actuall position of the wastegate
Originally Posted by cookie88
MAP sensor. At ~5 psi the PCM commands the wastegate control solenoind to start to open, it's full open by 8 psi....so it's easy to see how at anything other than that 3psi window the wastegate will either be full open or full close.
The Wastegate Control Solenoid (WGCS) is NORMALLY CLOSED...as is the Wastegate Control Valve (WGCV). The WGCS is what we commonly call the actuator.
The RED tube from the intake manifold is connected to BOTH the solenoid and the valve. When there is no current being supplied to the solenoid, all boost from the manifold is allowed to act on the valve to open the wastegate.
The PCM provides a pulse width modulated signal to the solenoid. This signal opens the solenoid (how much depends on the duty cycle) and allows boost pressure in the red line to be bled off into the green line that connects to the inlet of the turbocharger. The higher the duty cycle, the less boost is acting on the valve to open the wastegate.
When you stab the throttle, the solenoid goes to 100% (practically) to hold the WG shut and allow the truck to build boost. As the boost comes up, the duty cycle will drop and begin opening the WG. 65% Duty Cycle would mean that the WG is opening 35% (roughly, I'm not sure that the actual movement of the WG is linear in relation to the % DC)...you get the picture.
