390 towers
Old 10-24-2006, 11:26 AM
76fordo's Avatar
76fordo
76fordo is offline
390 towers
will 390 towers bolt up to the stock drilled holes on the frame in a 76 high boy.
I'm looking to fabricate 390 towers if they will bolt up to the frame. Im going to run a 302 and it sits alot farther back because iots a shorter block.
Old 10-24-2006, 12:59 PM
Freightrain's Avatar
Freightrain
Freightrain is offline
You could get an FE back then so I can't see why they wouldn't? Why not find someone on here to give you a factory set?
I've never compared....are the towers the same between big and small block, just moved to different location?
Old 10-24-2006, 08:57 PM
1975Ford's Avatar
1975Ford
1975Ford is offline
The towers for a 302 cid and 390 cid are different towers.
If you can find towers for a 302 cid the swap will go much smoother.
76fordo
10-27-2006 03:17 PM
76fordo
09-28-2006 09:47 AM
f-250.4x4.390
06-19-2004 09:26 AM
neer150
Engine Swaps
05-17-2004 10:07 PM
stock_460
03-20-2002 11:34 AM
Quick Reply: 390 towers
