2003 F250 Power window won't work, HELP - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-24-2006, 01:09 AM
meyer712 meyer712 is offline
meyer712 is starting off with a positive reputation.
Talking 2003 F250 Power window won't work, HELP
Greetings,
I have a 03 f250 Powerstroke 4 door. The drivers window switch won't raise the window. I think I have to replace the switch. Is there any idea of how to roll the window up by jumping a wire or a manual way of doing it. Wisconsin in the winter is not the time to drive around with the window down. Also any ideas of where to get good used oem parts or cheap oem parts. I think I am in need of the switch cluster for the windows.... Thanks in advance
Gene
Old 10-24-2006, 06:28 AM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
Thread moved to Super Duty forum.
-Matt
Old 10-24-2006, 03:20 PM
RACERX7775's Avatar
RACERX7775 RACERX7775 is offline
PROFESSIONAL KNOW-IT-ALL
RACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to behold
you can remove the door panel and run a power and ground directly to the window motor and see if it moves. power and ground positions should be reversed on the motor to move the window the other way. if it still does not move, the motor is bad. i would do this before i would purchase the new switch because they are not returnable.
Old 10-24-2006, 03:40 PM
Lonewolftx's Avatar
Lonewolftx Lonewolftx is offline
Lonewolftx is gaining momentum as a positive member of FTE.Lonewolftx is gaining momentum as a positive member of FTE.
Arrow A long this line . . .
Can you get a an "Auto Down" switch to change out on the passengers door? Could the Moon roof switch be used for that as it is an "auto open/down) one as well?
The switch bank on the Drivers door is one unit so I am guessing that you can't add that feature to the passenger window switch either?
Not trying to . . .
A1electric power window problem wiring. Happynone92 Aftermarket Products 0 08-28-2016 11:39 PM
Power Windows to Manual BigBlue99 1999 to 2016 Super Duty 5 04-23-2012 04:05 PM
Window Won't roll down all the way ltfire99 1999 to 2016 Super Duty 1 08-24-2009 09:26 PM
power window won't go up - bad switch? rschleicher Escape & Escape Hybrid 4 01-09-2007 06:28 AM
Electric windows won't go up markbrown47 1987 - 1996 F150 & Larger F-Series Trucks 1 12-01-2006 10:48 AM
Tags
2003, 2005, 250, diesel, f250, f250power, ford, passanger, power, window, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
