79 F-150 Fuse Diagram - Ford Truck Enthusiasts Forums
Old 10-23-2006, 06:46 PM
idgit0488's Avatar
idgit0488 idgit0488 is offline
idgit0488 is starting off with a positive reputation.
Where can I get a diagram of the fuse panel? My brake lights, tail lights and reverse lights are all out.
Old 10-23-2006, 07:05 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
If the horn works I suspect the NSS on the transmission is really dirty causing the B/U lights not to work........common problem
Old 10-23-2006, 07:09 PM
idgit0488's Avatar
Awesome! Thanks man.
Old 10-23-2006, 07:25 PM
rboeding rboeding is offline
rboeding is starting off with a positive reputation.
If the fuses are good check the ground. I replaced my ground cable this weekend with one that had a little pig tail on it with a spade. I bolted it to a near by bolt. The lights are brighter and the turn singals are stronger and everthing electrical runs the same at idle or at speed. Don't underestimate the ground.
Old 10-24-2006, 11:54 PM
idgit0488's Avatar
when you say ground cable, are you referring to the negative battery cable? Just want to clarify because I saw the tailights have ground wires coming off of the back of the bulb fixture. The wires were in good shape and had a solid ground.
Old 10-24-2006, 11:58 PM
idgit0488's Avatar
Quote:
What is an NSS? Where about would it be located on a C6?
Old 10-25-2006, 01:01 AM
NSS = Neurral Start (safety) Switch.
It is located on the side of the transmission.
Old 10-25-2006, 10:48 AM
idgit0488's Avatar
What would you recommend to clean it with? I've got some carb and brake cleaner in the toolbox...
Old 10-25-2006, 02:13 PM
1985 F250 5.8L wiring diagrams and fuse box diagram coatesgirl4 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 34 04-26-2016 10:17 PM
need dome light diagram centralNH 1967 - 1972 F-100 & Larger F-Series Trucks 18 04-11-2014 06:36 AM
Fuse diagram for 73 F250 73AlgonaMom 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-19-2014 01:37 PM
79 F250 fuses beaable Electrical Systems/Wiring 4 11-05-2007 09:55 PM
fuse diagram yjtrendsetter 1997 - 2003 F150 5 02-24-2002 07:39 PM
Tags
1979, 78, 79, box, custom, diagram, explorer, f150, ford, fuse, lights, location, panel, ranchero, reverse, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
