Stink
You might see if you can rent a fogger, or ozone generator. Fire/flood restoration company's use them to deodorize burned places. A fogger is like a kettle that heats this scented oil and blows the smoke all over, when you do a house, you can't see from the smoke it creates. I'd say do the fogger and if it doesn't work, try an ozone generator. If you can't rent a fogger, you may be able to have someone come out on a service call and do it for you. You may be able to find the oil only and 'somehow' burn it and make it work, but don't quote me on that.
If you cannot have a steam cleaner clean the seat on the top and under ( have to remove the seat), then the " hang from the mirror" air freshners will work until the rat smell dies....
Those air freshners that smell like fresh pine trees just cut down will work, but your truck truck will smell like a rat that died in a pine tree. Not much else to do except mother time to kill it. good luck to you.
Received 3,697 Likes
on
