Vacuum diagram - Ford Truck Enthusiasts Forums
Vacuum diagram
Old 10-21-2006, 10:53 PM
nosnilla1 nosnilla1 is offline
nosnilla1 is starting off with a positive reputation.
Vacuum diagram
I would like to locate a vacuum diagram for a '78 F-250 2wd Supercab, 460, 4 barrel (Motorcraft 4350), C6, 3.54 axle ratio, engine decal says "Non-Catalyst" D8TE-9C485-BKB. The truck is operating in Canada and was not fitted with an EGR valve, air pump or Cat. from the factory. Thanks for the help.
Old 10-22-2006, 01:47 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Dennis (Mil1ion) may have what you need.
Old 10-22-2006, 02:24 AM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
The D8T?-xxxx-xxx number on the engine decal is the decal part number
On the passenger side valve cover is there a white sticker ?
Once decoded it should come out as : 8-97-R0
This is your calibration number and it refeences to the actual driagram & the specs for the tuning of the engine.
Old 10-22-2006, 06:23 PM
Vacuum diagram
I looked on the passenger side valve cover but the calibration sticker is long gone. Any other way I could access a correct vacuum diagram? Thanks
Old 10-22-2006, 07:46 PM
Well, I haven't heard of a 78 w/o an EGR so it would have been great to have the sticker info.
I can put up a copy of the diagram but It would take a while to scan and send a copy of an illustration of where all the hoses run.
Old 10-24-2006, 11:08 PM
Vacuum diagram
It is always possible that the EGR valve may have been removed prior to purchase of the truck in 1986. The location of the EGR valve in after-market repair manuals appears to be on the rear of the carb. spacer. The carb spacer on this truck is a phenolic item with bonded gaskets. (I had to replace the spacer with a dealer supplied Ford part once when the stock carb was removed for overhaul and the gasket surface separated) There is no evidence of a mounting flange for an EGR valve on the spacer or on the intake manifold.
Old 10-25-2006, 12:52 AM
Okay so to be clear.
You want the original Emissions vacuum digram for a truck that doesn't have a EGR, air pump.
Are you in Ontario and have to pass an emissions test ?
I'll scan the 78 460 vacuum routing illustration tomorrow for you.
Old 10-25-2006, 03:52 PM
After checking out your web site and looking at your list of possible calibration codes it looks like 8-97-RO is the closest to my truck. I live in Edmonton, Ab., so no worries about emission tests. There are two devices in the vacuum system mounted on the passenger side valve cover. One, near the front has the following part # D8TE-9H301-AA, and the second mounted near the centre has vacuum and electrical connections (no #) any thoughts? Thanks for your help.
Old 10-25-2006, 10:11 PM
The front one (9H301-AA) is the vacuum vent valve.
Would you like the Illustration ?
Old 10-26-2006, 12:00 PM
Vacuum diagram
Yes, I would like a copy of the vacuum diagram. Thanks
Old 10-28-2006, 03:20 PM
rrswens rrswens is offline
rrswens is starting off with a positive reputation.
Is there any way I could get a copy as well?
Old 10-29-2006, 04:26 PM
Sorry for the delay, I will be scanning it this afternoon.
Old 10-29-2006, 06:11 PM
E-Mail sent.
Old 04-12-2014, 12:14 AM
PITAVAN PITAVAN is offline
PITAVAN is starting off with a positive reputation.
Hi Mil1ion, hate to revive an old thread but I was curious if you still had copies of the vacuum diagram(s)/hose illustrations for the 8-97-R0 calibration code. I'm dealing with the aftermath of a small thermal event (meltdown) leaving half the passenger vacuum hoses crispy!
Thanks!
Old 04-12-2014, 08:49 AM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Quote:
Thanks!
Welcome to FTE.
Unfortunately Mil1ion is no longer a member of FTE,
Vacuum diagrams; where to find them tbruz 1973 - 1979 F-100 & Larger F-Series Trucks 6 01-15-2017 11:19 AM
1994 f250 connector c103 diagram BearFootCustom 1987 - 1996 F150 & Larger F-Series Trucks 4 07-18-2016 09:24 PM
Harley HarleyP 1973 - 1979 F-100 & Larger F-Series Trucks 0 05-02-2014 08:44 AM
Climate control vacuum diagram choptop49ford 1973 - 1979 F-100 & Larger F-Series Trucks 0 09-15-2013 10:08 PM
Vacuum Diagram? bass-n-fire 1994.5 - 1997 7.3L Power Stroke Diesel 2 07-28-2011 08:05 PM
Tags
1977, 2006, 360, 4350, 460, 78, 897ro, air, barrel, calibration, d8te9c485bkb, diagram, ford, intake, motorcraft, sysystem, vacum, vacuum, vulcan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
