gremlins in 2000 navigator
my 2000 navigator has some weird things going on. the blower motor runs by itself the radio turns on and off by its self the running board lights come on and off by their self and you can here it chiming inside like the door is open. all this happens with the key out of the ignition and the doors locked. anybody have any ideas has to what the problem is?
Bummer, b/c if you did it would be an easy fix. Indiscriminant electrical problems like you described are difficult to diagnose. My best guess would be a deteriorating wiring harness that carries wires from all the affected systems. Best advice I can give is to get a wiring schematic for your vehicle and see if you can ID a common connector. Also, do a thorough search here and elsewhere and see if anyone has had a similar issue. Good Luck!
rhino_160
1997-2006 Expedition & Navigator
10-23-2008 12:12 AM
Corona Freak
02-01-2008 04:21 PM
bdf
09-19-2006 07:20 PM
