bed removal
bed removal
You should have braces from the rear of the rear fenders to the frame that must be taken off and the bolts connecting the running boards to the rear fenders must also be removed. The bed is alot less bulky and easier to handle if the fenders and tailgate are also removed from the box. Get three other people to help, have saw horses ready to place the box on once removed. Good luck and be careful.
bed removal
The crossmembers should be part of the frame. To make sure though, crawl up under there and have a look!!! The crossmembers should be welded to the frame. Once you remove the bed bolts, elecrical wires to the rear lights, etc, it should come off. Be sure to trace any tube or cable runs that might be clipped or screwed onto the bed. Once you start taking the bed off the frame, do it at first in 6" to 12" at a time, checking to make sure nothing else is still attached. Check and DOUBLE CHECK... it's worth your time, believe me!
Good luck,
DS
Good luck,
DS
