How do you remove the key door lock, I dont see what is holding it in place I want to remove it so I can repair my door hanle , it will not open from inside something came loose. Thanks
there should be a tiny screw right inside a little hole on the door edge. I haven't taken mine off, but that's the only thing that I can see holding it in. You might have to take the door locks out too when you try and take that out. Anyone else?
The standard locks use a screw while the 5 star cab uses allen keys. I tried to get the locks out of my parts truck and turned the allen key into a drill bit(twisted it all up)
