Flowmasters?
I have a Flowmaster 40 muffler in the stock exhaust system on my rig. Has good flow and a nice tone when you get on it. Not insanely loud but has a nice roar especially when your pulling a load. Works great and has metal fins inside the muffler so no worries about plugging it. Would sound alot better with a larger exhaust though...
-Dave
-Dave
We tried to buy one (probably a 40) from a local performance warehouse a couple years ago to put on a bus and the guy wouldn't even sell it to us. He said they weren't for diesels. We found out what he ment a few weeks ago. We had a different bus come in with a pair of 3 inch Flowmasters on it. One had the whole side blown out of it. This was on a Detroit diesel, so a lot bigger and lots more air due to the blower, but still. I'd never put a baffled muffler on a diesel.
Yes, I'm calling the FM baffled. Sorry, I don't like K&N air filters either.
Originally Posted by cookie88
Flowmaster does have straight through mufflers for turbodiesel applications now.
Welcome to FTE paw73!!
I personally fail to see how a Flowmaster could get the case blown open. Besides the fact that they're made of very heavy gauge steel, the cases are fully welded. Those things are pretty stout.
Only reason I could see was if the exhaust was too small for the engine in question, and there was an excess of pressure in the muffler...but with a 40 series that seems unlikely...I dunno.
If I can pick up a truck with an IDI like I'm wanting to, I'm already planning out a nice 3.5" or 4" exhaust system with a big 40 series on it
yah, i dont see how they would blow out. From what I have seen, and I've worked with a bunch of 40's on gassers and to me they are way better built then most other mufflers. All the welds are clean and metal is of high quality, so unless your putting them on a big rig or someting then I dont see how theyd blow holes in em.
not to mention a 302 can easily outflow a 7.3L..a 302 at 5000rpm flows 437cfm. A 444 at 3000 flows 385cfm. Those rpm figures are conservative. Most people dont push their engines past that. Lots of people run at least dual 2.5", if not dual 3" on the 7.3L. Most people run 2.5" on a 302, that is passing more cfm through generally smaller pipes = higher pressure. So if the Flows last on a gasser engine they should easily last on an IDI.
Ok I was at the salvage yard looking for a rear seat and I literally tripped over what i thought was a POS muffler. It was actually a flowmaster 40 series. 20 Bucks and it was mine, welded it on and it sounds freakin BAD A. Its got a deep tone, somewhat like a gasser with flows, but of course it is way louder. My truck jumps off a light instead of slowly gaining speed, I dont;t know if its the muffler or the colder weather but the muffler is helping
