How to tighten flywheel? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 10-19-2006, 10:22 AM
5.0 ford 5.0 ford is offline
5.0 ford is starting off with a positive reputation.
How can i bolt the flywheel on without it spinning? i took it off with an impact wrench but ill need to use a torque wrench to bolt it back up.
Old 10-19-2006, 10:24 AM
agryphon agryphon is offline
agryphon is starting off with a positive reputation.
You may need to wedge a large screwdriver in the teeth to stop it spinning while you torque the bolts.
Old 10-19-2006, 12:43 PM
fordboy_52's Avatar
fordboy_52 fordboy_52 is offline
fordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to behold
wooo, dont do that. if its an auto, u can put a pair of vice grips on it over the teeth without hurting the teeth. if its a manual you can do the same just make sure to not harm the pressure surface. make sure u dont drag the vice grips so you dont tear the surface.
Matt
Old 10-19-2006, 01:42 PM
G2IC_Wraith G2IC_Wraith is offline
G2IC_Wraith is starting off with a positive reputation.
Or get a tool that will do the job. Made my life easier. Click me.
302 flywheel confusion mh822 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 76 01-14-2017 03:49 AM
Torque specs, flywheel and pressure plate bolts cadunkle Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 11-19-2016 07:59 PM
Flywheel and Pressure Plate Torque Specs NS70250 1967 - 1972 F-100 & Larger F-Series Trucks 0 04-09-2016 03:35 PM
Flywheel removal Ed Bamba 1987 - 1996 F150 & Larger F-Series Trucks 14 01-13-2012 12:20 AM
Strange torque on 460 flywheel bolts rhoward 1987 - 1996 F150 & Larger F-Series Trucks 4 10-16-2009 08:21 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
