Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-19-2006, 01:59 AM
fordinmudd's Avatar
fordinmudd fordinmudd is offline
fordinmudd is starting off with a positive reputation.
78 79 DANA 60s?
does anyone know if the dana 60 front axles on a 78 and 79 f 350 4x4 are the same as a 1988 f 350 4x4 dana 60 front axle?thanks
  #2 (permalink)
Old 10-19-2006, 02:33 AM
blackford85 blackford85 is offline
blackford85 is starting off with a positive reputation.
Hmm, im not too sure on this one. I might be mistaken but i know the 76' and older highboys had a high pinion(reverse rotation) differential and kingpin knuckles instead of ball joints. To me the kingpin axles are more desirable because they are longer lasting and have more driveshaft to ground clearance. As for differences thats wat i can come up with but as long as the gear ratios match it shood be a direct bolt in swap depending on wheel stud sizes.
  #3 (permalink)
Old 10-19-2006, 07:21 AM
cleatus12r's Avatar
cleatus12r cleatus12r is offline
cleatus12r has a great reputation on FTE. cleatus12r has a great reputation on FTE. cleatus12r has a great reputation on FTE. cleatus12r has a great reputation on FTE.
No the axles are not the same. They have a lot in common but are not a direct bolt-in. The 78/79 axles have narrower spring mounting points (closer together by roughly 4 inches). This puts the leaf spring mounting pad on the driver's side cast into the differential housing vs. on a mostly separate pad on the axle tube. Also of note would be axle shaft differences. The later axle shafts are larger diameter (more splines) and subsequently stronger. Up until the end of '91 the Ford Dana 60 axles had kingpin knuckles. After that, the ball joint style was used.
Cody
  #4 (permalink)
Old 10-19-2006, 10:13 AM
ivanribic ivanribic is offline
ivanribic has much to be proud of ivanribic has much to be proud of ivanribic has much to be proud of ivanribic has much to be proud of ivanribic has much to be proud of ivanribic has much to be proud of ivanribic has much to be proud of ivanribic has much to be proud of
Quote:
Not to be nit-picky but I'd just like to point out that these axles are not reverse rotation. They still rotate the same direction as other front axles. They are referred to as reverse cut or reverse spiral because the ring and pinion is cut so that it's driven from the drive side of the gear rather than the coast side. I'm not certain on the entire year range but I know that the 78 and later axles used the high pinion reverse cut setup.
Cody covered all the other differences. In terms of the smaller inner shafts (78 and 79) they can be upgraded for pretty cheap to the non-neckdown style. You cannot swap in the later stock axles as they're different lengths. Both the 78/79 and the later axles used the smaller 30 spline outers and the outers are the same for both axles so when upgrading stubs there's not a particular year range you need to look for. Just make sure they're the Ford stubs, not the Chebby stuff.
  #5 (permalink)
fordinmudd's Avatar
thanks i really wasnt sure but i know about them having kingpins.my dana 60 on my 88 has kingpins.thanks for letting me know there not a direct bolt-in.
  #6 (permalink)
Old 10-19-2006, 10:15 AM
fordinmudd's Avatar
good thing i came and checked first i didnt know they had smaller splines.oh no no no i would never buy chevy stuff thats a no no. ok well the guy was going to sell the axle cheap but since off the 78 but it wont bolt right in so i guess i wont buy it.
  #7 (permalink)
Old 10-19-2006, 10:21 AM
Well, both axles have the same number of splines. Stock, they're both 35 spline 1.5" inners and 30 spline outers. The difference is that in the 78/79 D60's the inner axle tapers down after the splines. I don't remember the exact size but it's somewhere around 1.25" for the length of the shaft. The later D60's stay at 1.5" for the whole length of the inner shaft. I upgraded my inners for about $150 (for the pair) and the aftermarket replacements do not neck down. Below is a comparison picture of my old vs new inners, short side:
  #8 (permalink)
Old 10-19-2006, 10:26 AM
Quote:
BUY IT!
You can put a 78/79 axle in a later model truck pretty easy. It's a late model axle in a 70's truck that is tough. All you'll need to do is buy a set of spring perches and weld them in, or get one spring perch for the drivers side and move the passenger's side perch a couple inches. So rather than the driver side leaf spring sitting in the perch cast into the housing it'll sit on a perch mounted on the short side tube.
Btw, 78/79 are also more desirable for people who want to do radius arms/coil springs because it allows the radius arms to stay in closer and gives you more short-side tube to work with.
  #9 (permalink)
Old 10-19-2006, 10:55 AM
RotGrubestier44's Avatar
RotGrubestier44 RotGrubestier44 is offline
RotGrubestier44 is gaining momentum as a positive member of FTE.
YEAH, BUY IT!!!!!
You would be a FOOL not to. Even if you don't have a welder, or can't weld, getting the perches welded on, or the Radius Arm C-mounts if you do decide to go radius arms and coils is well worth the strength and reliability of the axle. BUY IT.
__________________
Jeep... Its whats for Dinner!!!
The problem is Mud. The solution is Ford.
www.workingpitbull.com
www.broncograveyard.com
www.buckstop.biz
  #10 (permalink)
Old 10-19-2006, 01:21 PM
fishmanndotcom's Avatar
fishmanndotcom fishmanndotcom is offline
fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE.
no dont buy it! you cant use it, not to mention those 78/79's were weeeaaaakkkk! almost as bad as the closed knukles!
where is this axle at? and how much is cheap? i need to know for market value purposes
-cutts-
__________________
My Google Photo Gallery
-96 F350 4x4 ZF5 CC/LB, 37" SSR's, D66 turbo, Stage-1's, Banks IC, 5" stacks, York OBA
-72 Bronco 302/NP435/D20/D60/10.25 welded F/R, full hydro, hydroboost, 39"iroks
  #11 (permalink)
Old 10-19-2006, 05:20 PM
MBBFord's Avatar
MBBFord MBBFord is offline
Genius
MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold
Talking
-cutts-
I was waiting for this one!
How much is the guy selling it for though?
__________________
79 Bronco 400 C6 NP205 D44 9" 4.56 gears Lockers 6" lift and 37" SS Iroks
77 F-100 302 C4 D44 31" M/Ts
04 F150 Lariat Screw 4x4 2"AS 32x11R17 Hankook M/Ts or 34x10.50-17 SS LTBs
  #12 (permalink)
Old 10-19-2006, 05:21 PM
Thomasm67's Avatar
Thomasm67 Thomasm67 is offline
Thomasm67 is gaining momentum as a positive member of FTE.
And for the record 76-77 Hiboys are not hipinion as i own one Hiboys had a divorced Tcase. 77 1/2 F250's to 79 had the married Tcase which then they would have either a hipinion D44HD or D60.
__________________
Only the Best and Finest Drive Ford Trucks in the
Kansas Chapter
76 F250 Hiboy/390/35's/4.10's
92 Explorer/3.73's/4.0/235's
  #13 (permalink)
Old 10-19-2006, 10:19 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader SwOkcOffRoader is offline
SwOkcOffRoader is gaining momentum as a positive member of FTE. SwOkcOffRoader is gaining momentum as a positive member of FTE.
i still have yet to see a 77.5 "lowboy".........but i dont wanna start a highboy/lowboy arguement ....
__________________
If a hammer doesnt fix it, you have an electrical problem!!
Do you like Myspace?? Then Check out Mymudspace.
My myspace Page.
My mymudspace Page.
  #14 (permalink)
Old 10-19-2006, 10:53 PM
Thomasm67's Avatar
Drop it off in a ghetto and it will be
__________________
Kansas Chapter
  #15 (permalink)
Old 10-19-2006, 11:11 PM
fordraceboy fordraceboy is offline
fordraceboy is gaining momentum as a positive member of FTE.
the D44HD wasn't a high pinion. they went to high pinion when they did the whole highboy/lowboy divorced/married changes....
__________________
I could use another beer.....
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
