Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-18-2006, 01:22 PM
P51D Mustang is starting off with a positive reputation.
Crank, oil seal, and block compatibility?
Recent questions about putting 302 or stroker cranks in 289 blocks.. ect.. has me thinking about the one piece and two piece oil seals. I'm unclear about what oil seals work in which blocks, and with which cranks.
Doesn't a two piece oil seal crank need a two piece oil seal, and the block and rear cap need to also be for a two piece oil seals?
Most stroker crank's are intended for modern 5.0L blocks that are one piece oil seal set ups.
Who knows the low down on this?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 10-18-2006, 09:21 PM
baddad457 is starting off with a positive reputation.
If I'm not mistaken, you can use a two piece seal crank in a one piece block, but not vice-versa. The one piece crank lacks the oil slinger ring to keep the oil away from the seal (or is it the knurling?) The one piece seal doesn't fit a two piece block whatsoever, so you have to use which ever seal the block requires.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
