Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-17-2006, 01:04 PM
tromano32 tromano32 is offline
Garage is empty, add now
tromano32 is starting off with a positive reputation.
Exclamation 1960's Econoline Van/truck vin help
I just got this van/truck and I do not know the year. I have the vin and I was wondering if anyone could decode it for me or lead me to where I could decode it.
Thanks
Vin E10TH660557
  #2 (permalink)
Old 10-17-2006, 06:01 PM
Jimbare's Avatar
Jimbare Jimbare is offline
all alone in the world
Jimbare is gaining momentum as a positive member of FTE.
will have it tomorrow.
if you will send the data plate info i will decode it for you also.
__________________
jim
underated and overworked.
  #3 (permalink)
Old 10-19-2006, 05:46 AM
Jimbare's Avatar
i'll try this again, psted last night and it didnt come thru!
E10 = Econoline pickup
T = 170 engine
H = Lorain Ohio assembly plant
660557 = March 1965 serial number (1965 model
__________________
jim
  #4 (permalink)
Old 10-19-2006, 09:34 AM
Thanks alot.... were do you get this info?
  #5 (permalink)
Old 10-19-2006, 06:25 PM
Jimbare's Avatar
i have a super secret decoder ring!
__________________
jim
  #6 (permalink)
Old 05-26-2010, 07:38 AM
thusak thusak is offline
thusak is starting off with a positive reputation.
I have a 1961 Ford Econoline Pickup with the VIN number E10TH221101 can you tell me what year it is and is the model of the truck an E100 or an E103. Thanks for any help you can give me. Tim
  #7 (permalink)
Old 05-27-2010, 04:00 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Welcome to FTE
E10 = E100 1/2 ton Pickup
T = 170 1V I-6
H = Lorain OH Assembly Plant
221101 = 1962 assembled October 1961.
The MODEL code is listed separately on the Warranty Plate.
It could be E103 or E104.
All 1961/67 Econoline's are E100's. 1969 is the first year for E100/E200/E300's.
Even though this new model Econoline was introduced Spring 1968, Ford refered to them as 1969's.
VIN decoded using the 1957/63 Ford Truck Parts Catalog.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #8 (permalink)
Old 05-27-2010, 06:56 AM
Thanks Bill,
This will help me out, I was wondering why when I got the title it read E103 and the year was a 1962 because the guy that sold me this truck said it was a 1961. Thanks and have a great day.
  #9 (permalink)
Old 05-27-2010, 01:56 PM
Ford Parts Guru
2013 Ford Escape
Thanks Bill,
E103 is the MODEL code as listed on the Warranty Plate.
E103: 1961/64 Econoline 1/2 ton pickup / 3600 lbs. Gross Vehicle Weight Rating.
Back then, some states registered vehicle by the year they were first sold, not by the actual year of the vehicle.
Since your 1962 Econoline was assembled in October 1961, it may have been sold in 1961...and so was registered as a 1961.
Most sellers (especially on ebay and Craigslist) are clueless, don't know diddly-squat about the vehicles they own.
__________________
  #10 (permalink)
Old 07-27-2010, 07:24 PM
poisonivyecono poisonivyecono is offline
poisonivyecono is starting off with a positive reputation.
Question I have no clue
I just got an Econoline p/u and i am not sure what year it is. I have no paperwork on the car. The vin is E10SH125752. I would appreciate any help!!!
  #11 (permalink)
Old 08-03-2010, 11:30 AM
motor-officer motor-officer is offline
motor-officer is starting off with a positive reputation.
ECONOLINE HELP
I am looking at an old Ford Econoline truck. There is no VIN data plate on the door. The title states the VIN number as "E10TH457496" and that it is a 1967. Does this VIN correlate with the year 1967? Also is there any other specific locations where the original VIN is stamped that a person can actually find? Thank you for any info.....
  #12 (permalink)
Old 08-03-2010, 10:57 PM
66gpw's Avatar
66gpw 66gpw is offline
66gpw has a good reputation on FTE.66gpw has a good reputation on FTE.
Look on the metal braces behind the taillights. There is usually a factory serial stamped on one of these. That will be the original.
The other location is under the doghouse of the motor. This requires you to unbolt and clean the seal goop that the doghouse boltd to. There again should ba serial number from the factory there also.
These are more reliable since they are stamped into the sheet metal. Doors get changed and the door tags do not or get removed.
Those numbers you posted are the serial number numbers, if they match the brace numbers then they are the original.
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
78 F250
Tags
1960, 1960s, decoder, diesel, e10, econoline, forums, number, numbers, plate, serial, small, van, vans, vin, warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
