1960's Econoline Van/truck vin help
I just bought a 65 econoline pick on ebay got title in the mail but i dont have truck yet . the vin# is E14TH505336 I was hopeing someone could help me decode it. Everything I have found shows E14 as a van and E10 as a pickup.I hope its the right one for the truck. thanks
E14TH505336 VIN Data
If you have the other data from the door plate, you can enter it on that website and instantly know everything about your Econoline.
Econoline dot org
Received 3,090 Likes
on
this forum is for the falcon based ranchero
you will get a better responce in the 57 to 60 pickup forums, found here: 1957 - 1960 F100 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
on
For all 1961-1967/68 Econolines, go here and search to see if your Econoline is already in the database.
Econoline dot org list
If yours is not listed, you can enter the VIN and all of the door tag information here and get an instant decoding.
Decode Econoline VINs Here
on
That Econoline VIN decoder that hinzec mentioned works for only 1961-1967 Econolines.
FYI - This part of the Ford Trucks forum is for 1961-1967 Econolines. I am not kicking you out, just letting you know that there is a place here where folks who own vans your age hang out.
https://www.ford-trucks.com/forums/forum128/
Best wishes in your Club Wagon restoration.
#29
1965 Econoline Pickup
#30
I also just purchased a 1965 Econoline pick up and am learning all about the codes. Try the other codes on the same ID tag, can tell what month, the original color, body style, upholstery and transmission It's the 87B style (5 window) that is custom and had lower build population - 3065 vs. 4340 for the 87A standard van (3 window). I'm in Denver and will get started with this new fun project
