Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-17-2006, 07:43 AM
1975Ford's Avatar
1975Ford 1975Ford is offline
1975Ford is gaining momentum as a positive member of FTE. 1975Ford is gaining momentum as a positive member of FTE.
Lightbulb Dual Water Temperature Guage Setup ? on FE Engine
Would like to include two water temperature guages (one OEM guage and one aftermarket cooling temperature guage) with sensors on a 390 FE engine.
This 1976 F150 truck has the original water temperature guage and has the cooling OEM temperature sensor mounted in front of carburator on a Edelbrock 4 bbl intake on a FE engine.
I thought of installing the aftermarket sensor to the Edelbrock intake (currently where the OEM temperature sensor is mounted) and relocating the OEM temperature to the water neck. I was planning on taking the water neck to a machine shop to get the water neck machined and rethreaded to fit the OEM cooling temperature sensor thread.
Does any company sell the FE water necks with the hole to mount the OEM cooling temperature sensor?
And ideas or suggestion on mounting dual cooling temperature guages and sensors, appreciated .
__________________
Duraspark
  #2 (permalink)
Old 10-17-2006, 08:55 AM
FalconStng FalconStng is offline
FalconStng is starting off with a positive reputation.
I left the factory sending unit in the intake manifold. There are many available Thermostat housings that are tapped. I installed the aftermarket water temp in one of those. The aftermarket gauge kit I purchased had adapters and there was one that fit the thermostat housing.
Good Luck!
Tracy
  #3 (permalink)
Old 10-17-2006, 11:50 AM
1975Ford's Avatar
Thanks, found one in chrome (@ the AZone) includes the gaskets and bolts and has the hole for the sensor.
__________________
Duraspark
  #4 (permalink)
Old 10-18-2006, 04:16 PM
1975Ford's Avatar
What a good sealing product to seal the thread joints?
__________________
Duraspark
  #5 (permalink)
Old 10-18-2006, 04:33 PM
teflon tape.
  #6 (permalink)
Old 10-28-2006, 11:44 PM
1975Ford's Avatar
Here a picture of the aftermarket water temperature sensor hooked up to the water neck on the a 390 FE engine. http://www.ford-trucks.com/user_gall...132490&width=0
Teflon work really good in sealing the threads.
__________________
Duraspark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
