cruise control relay?? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 10-17-2006, 12:56 AM
pjohn192 pjohn192 is offline
pjohn192 is starting off with a positive reputation.
Just bought a 95 Ford F-350 powerstroke, and everything works except the cruise control. All the fuses in the cab, and under the hood are good. The owner's manual does not show a relay for the c/c. The question is: There are two relays off to the side of the fuse box in the engine compartment, that are not listed in the book. Is one of these the c/c relay? If not, does anyone know where to find it, or any other ideas as to why the cruise control doesn't work? Thanks..
Old 10-17-2006, 07:42 AM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.
The switch on the end of the master cylinder is probably bad. Pull the plug and check across the pins on the switch, should be continuity, if not replace it. BTW: these switches are the subject of a recall, they can cause a fire. I'd replace it anyway.
I'll check the book for the relays and post it.
Old 10-18-2006, 10:33 PM
Well, I tested the switch on the end of the master cylinder, and had power coming out of both wires. So I took it to my buddy's shop, and had them hook up a scanner to it, and it didn't bring up any codes at all except for no back pressure on the exhaust(which is because I put a 3" downpipe, and a 4" straight pipe on it. Any other suggestions?? Thanks..
Old 10-19-2006, 11:40 AM
plowhand's Avatar
plowhand plowhand is offline
Playing in the Dirt
plowhand has a good reputation on FTE.plowhand has a good reputation on FTE.
Check your third brake light wiring and bulbs. Cruise will not work with a blown third brake light or bad connection in the third brake light sockets. Also check you regular brake lights.
Old 10-21-2006, 06:46 AM
Cuda_jim's Avatar
Quote:
That may be your problem! The Switch is bad if you have voltage without the brake pedal being pushed.
Unplug the connector @ the (BPS), end of the master cylinder. Check the switch not the connector for continuity. You should get continity with the brake pedal depressed. It has no continuity while at rest. There are no codes set for this switch.
B/O cruise control and horn, '02 F150 Lariat chardagha 1997 - 2003 F150 2 06-24-2015 08:39 PM
2008 F250 Cruise Control stopped working Sugars Pop 1999 to 2016 Super Duty 12 02-20-2013 03:23 PM
cruise control help 78fordman 1968-2013 Full Size Vans 5 12-27-2011 07:53 AM
No Horn or Cruise Control thedeafone 1997 - 2003 F150 7 06-25-2004 11:19 PM
Cruise control help MikerMan Electrical Systems/Wiring 5 09-19-2002 07:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
