2001 Sport Trac 4 Wheel Drive - Ford Truck Enthusiasts Forums
Old 10-16-2006, 09:49 PM
griebel griebel is offline
griebel is starting off with a positive reputation.
Have a 2001 Explorer Sport Trac - the 4 wheel drive has gone out - was told it is a module - is this easy to replace?
Old 10-19-2006, 11:09 AM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
first check for B+ on the brown clutch wire at the T/C when the switch is in 4hi,
if no,
find fault, fix,
it will not engage front drive if there is no power at this point.
If yes,
check if T/C shift motor works when you press the 4low,this changes the ratio.
if no,
rebuild the motor, rear/drivers side of the T/C
2004 sport trac tailgate team key largo Explorer, Sport Trac, Mountaineer & Aviator 0 10-05-2015 10:40 AM
Last generation kenny nunez Explorer, Sport Trac, Mountaineer & Aviator 5 04-21-2015 07:59 PM
2001 sport trac help acook3323 Explorer, Sport Trac, Mountaineer & Aviator 0 02-14-2015 11:42 AM
Will a 2007 cover fit a 2001? robo5555 Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners 2 02-10-2014 04:00 PM
Explorer Sport Trac RonBo Explorer, Sport Trac, Mountaineer & Aviator 9 07-25-2001 08:20 PM
Tags
2001, drive, explorer, ford, module, sport, trac, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
