Engine Heaters - Ford Truck Enthusiasts Forums
Engine Heaters
Old 10-16-2006, 08:16 PM
bigblu78's Avatar
bigblu78 bigblu78 is offline
bigblu78 is starting off with a positive reputation.
Engine Heaters
When I put my new engine in my truck I had removed the factory block heater because I was told about issues with the block cracking. I would like to put some sort of heating unit back in my truck but I am unsure what to get. Does anyone know a good unit or what I should or shouldn't look for? I have seen the heaters that go in the radiator hose but I'm not too sure of those.
Thanks
Old 10-16-2006, 08:45 PM
Learath Learath is offline
Learath is starting off with a positive reputation.
havnt seen the hose one. i have seen one at napa that you put down the dipstick tube. i was thinking about brazing a heating element to the oil pan at some point.
Old 10-16-2006, 09:05 PM
dieself250 dieself250 is offline
dieself250 is starting off with a positive reputation.
i have a 2000w tank style heater that plumbs into the heater hoses, it works very well
Old 10-16-2006, 09:47 PM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
Your block heater will be fine, that problem was with mid 85 and below year engines. Get a new BH and install it where it was........it will do the better job. That is unless you put an 85 or below engine in........
Old 10-16-2006, 09:57 PM
where would a block heater be located? i found a cord for one under my hood but i have yet to find where it went
Old 10-16-2006, 10:12 PM
Block heaters are just over the starter.........
Old 10-17-2006, 10:34 PM
bigblu78's Avatar
Quote:
Where did you get your heater?
Old 10-18-2006, 12:31 PM
bc6.9 bc6.9 is offline
bc6.9 is starting off with a positive reputation.
I installed a block heater on my 84, didn't work, lucky for me after finding out the problems that can arise...I do have a magnet style heater for the oil pan, works ok, doesn't work as well as a block heater, just warms up the oil.
Old 10-18-2006, 03:14 PM
well at least you will not have to wait for the oil to warm up befor you get oil flowing threw the engine.
Old 10-18-2006, 04:49 PM
pud pud is offline
pud is starting off with a positive reputation.
pan heaters are nice, when its really cold....warmer oil on start up is alwats a good thing. I want one. Ive got two block heaters also...I had the idea that a complete underhood blanket heater would be cool also...like instead of the insulated piece of carpet type thing that pins to the underside of the hood, you could have the same thing with a heating element, along with two block heaters and an oil pan heater lol...I spend my winters in working in camp where power is supplied through a diesel generator and I dont have to pay the bill.
Old 10-18-2006, 04:58 PM
Quote:
i got it from advance auto ,its a KAT'S by Five Star External Tank Engine heater part# 12200, it should be able to get from any parts stores
Old 10-19-2006, 08:14 AM
Racineracer052 Racineracer052 is offline
Racineracer052 is starting off with a positive reputation.
Thumbs up Webasto heaters
You can also try Webasto, its a big name in semi-trucking, and they expanded into the resedential market. IT works Great.
http://www.webasto.us/am/en/am_auto_heaters.html
Old 10-19-2006, 09:29 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
Racineracer,
Welcome to FTE and the IDI diesel forum.
Block heaters Rusty_Old_F250 1973 - 1979 F-100 & Larger F-Series Trucks 23 11-26-2011 02:02 PM
block heater?? bcaughhorn 1999 - 2003 7.3L Power Stroke Diesel 15 02-02-2011 04:16 PM
block heater? cOpE! Montana Chapter 6 10-29-2010 05:46 PM
Block Heater automaticj5 2004 - 2008 F150 11 11-17-2006 10:27 PM
Engine Block heater on 6.0 fordcountry 6.0L Power Stroke Diesel 17 11-24-2005 02:17 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
