Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Cleaning and Detailing Guides
- How to Repair a Paint Scratch
Step by step instructions for do-it-yourself repairs
Fixing a deep paint scratch
I accidently rubbed my wheelbarrow against my tailgate when it was down and put a deep 4" long scratch right down into the primer. :-(
What the best way to fix this?
In my previous life, I've tried filling a scratch on my beater car with touchup paint that came in a tiny bottle that looks like my wife's nail polish, but the outcome looked terrible to say the least.
I'll be going into the deal later this week for some warranty work, so I havne't asked yet, but I seem to remember seeing some reference to them selling touchup paint in a spray. Would this work better? I have an airbrush set that I'm tempted to try to fill the scratch with several layers of paint and then polish. Would that work also?
Depends on the scratch - most have their own situation. Best way is to have it repainted, but if it is not that bad, you might be able to do it yourself.
If you can find one of those small touch up bottles that match your paint, you can use it and then wetsand the scratch to get it to blend in. Once you have the scratch blended and sanded, then polish and wax it. I have done a few this way on different vehicles. If you take your time, and the scratch is not too terribly bad, you can blend it well enough it is not too noticeable.
Might be worth a try anyway before you pay someone else to fix it.
Originally Posted by TOL-Irene
Deep scratches may be touched-up by a professional and will look great, but over time, the touch-up paint has a tendency to disappear from pressure washing, etc. The best long term solution is to have the panel repainted.
I have repaired scratches in my wife's cars. Go to the dealership and get the touch-up paint using the color code, best chance of a match. Clean the scratch with alcohol and the apply thin coats allowing each coat to dry until there is a noticable bump, by feel, over the scratch. Using 2500 or 3000 grit wet sanding paper, using a spray bottle with water, gently spray and sand until smooth, and then use buffing compound and the scratch is gone, this has worked every time for me and with my wife, I had lots of practice doing this.
If you are really brave, try this link. I used them last year to do some paint wear along the sealing surfaces along the top edge of the door. If you know your paint cide you will get a exact aerosol match. I need CX (dark shadow grey) they were the only source I counl find it in a aerosol.
http://www.automotivetouchup.com/
dbossman
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
24
10-13-2012 11:50 PM
59flatbedford
03-21-2010 06:55 PM
boxcar1974
Appearance & Dress-Up
03-29-2004 05:52 PM
joeturbo
08-24-2002 09:28 PM
