F-350 DUALLY rear brake drums stuck/rusted? on - Ford Truck Enthusiasts Forums
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Old 10-16-2006, 08:46 AM
gary_b gary_b is offline
gary_b is starting off with a positive reputation.
Hello everyone,
I'm new to the site here (great website by the way) and have a brake question.
I have a 1997 F-350 DUALLY with the FORD full floating axle.
The rear brake drums are stuck/rusted? to the hubs. I have tried wire brushing and using penetrating oil where the drum slips over the hub, but it's still STUCK SOLID.(drums turn so brake isn't on)
IF POSSIBLE, I don't want to remove the axle and hub to get the drum off if I don't have to, or possibly distort the drum by hammering on it or using a puller.
Are these drums heavy/strong enough to not distort, if I use a drum puller while "tapping hard" on the drum around its diameter or near the stud area and do you think this will get the drums off??
Any suggestions to get these drums of will be greatly appreciated.
P.S. When reassembling, will putting antiseeze(sp?)compound on the hub where the drum slips over keep this from happening again?
Thanks in advance,
Gary
Rear Drum Removal for '62 F350 Dually ??? desertbus 1961 - 1966 F-100 & Larger F-Series Trucks 9 12-17-2012 12:20 AM
Replaced Rear Brake Drums? tonyford Escape & Escape Hybrid 9 10-07-2012 09:31 AM
Brake Drum Removal help kmacht 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 08-31-2009 06:43 PM
Brake Drum Puller jethro1 1961 - 1966 F-100 & Larger F-Series Trucks 5 11-02-2005 04:52 PM
How to get drum off 86 F250 3/4 Ton salewit 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 04-12-2005 03:25 PM
Tags
brake, drum, drums, dually, duelly, f150, floating, ford, full, puller, rear, remove, removing, rust, rusted, stuck, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
